Hello Friends,
I have a Problem with my project.
I use this Arduino Mega Board with build in ESP8266:
After flashing the ESP8266 with the latest AT Firmware that is supportet by Blynk (>see getting startet)
everything works fine.
The ESP connects to blynk, i can upload a sketch to the mega, and my blink app shows me my sensor data.
now i want to get the signal strengh printet to the serial monitor and to virtual pin V7.
the problem is, that the value is everytime “0”.
do this lib wiFi.h dont work with the esp? or what do i wrong.
thank you for your help and sorry for my bad english.
Here is my code:
#include <WiFi.h>
#include <ESP8266_Lib.h>
#include <OneWire.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET 4 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define ONE_WIRE_BUS 2 //ds18b20 module attach to pin2
OneWire oneWire(ONE_WIRE_BUS);// Pass our oneWire reference to Dallas Temperature.
char auth[] = "****";
char ssid[] = "WLAN-NSTZNK 2,4GHz";
char pass[] = "****";
#define EspSerial Serial3
//#include <SoftwareSerial.h>
// Your ESP8266 baud rate:
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
void pressure()
Blynk.virtualWrite(V5, (analogRead(A0)-102)*13.7895/819);
Serial.print("Press: ");
Serial.println(analogRead(A0));
void getTemp()
sensors.requestTemperatures(); // Send the command to get temperatures
Blynk.virtualWrite(V6, sensors.getTempCByIndex(0));
Serial.print("Temp: ");
Serial.println(sensors.getTempCByIndex(0));
void wlansignal()
long rssi = WiFi.RSSI();
Blynk.virtualWrite(V7, WiFi.RSSI());
Serial.print("RSSI:");
Serial.println(rssi);
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
sensors.begin(); // initialize the bus
// Set ESP8266 baud rate
//Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 8442);
//Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8442);
timer.setInterval(2000L, pressure);
timer.setInterval(10000L, getTemp);
timer.setInterval(4000L, wlansignal);
And the serial monitor:
[122]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.5.4 on Arduino Mega
[713] Connecting to WLAN-NSTZNK 2,4GHz
[3766] WIFI CONNECTED
AT version:1.1.0.0(May 11 2016 18:09:56)
SDK version:1.5.4(baaeaebb)
Ai-Thinker Technology Co. Ltd.
Jun 13 2016 11:29:20
OK
[8922] +CIFSR:STAIP,"192.168.2.57"
+CIFSR:STAMAC,"38:2b:78:04:75:50"
[8929] Connected to WiFi
[19408] Ready (ping: 13ms).
Press: 101
Press: 102
RSSI:0
Press: 116
Press: 101
Temp: 19.31
RSSI:0
best regards!
