I use Wemos D1 Mini + shields (DHT11, Relay + Funduino Soil Moisture sensor):
#include <DHT.h>
#include <SimpleTimer.h> //Good timer library
#define DHTPIN D4 // what pin we're connected to
#define Relay_1 D1 // Arduino Digital I/O pin number
DHT dht(DHTPIN, DHTTYPE);
int temp;
int humidity;
// SoilMoisture Value
int moisture_val;
char auth[] = "1.....d"; //Auth Token for project
// Blynk Led Widget
WidgetLED led(V4); //register led to virtual pin 4
dht.begin();
Blynk.begin(auth, "ssid", "pasword");
Serial.println("Blynk test!");
//-------( Initialize Pins so relays are inactive at reset)----
digitalWrite(Relay_1, LOW);
//---( THEN set pins as outputs )----
pinMode(Relay_1, OUTPUT);
delay(4000); //Check that all relays are inactive at Reset
// Setup function to be called every 2 seconds
timer.setInterval(2000, sendData);
}//--(end setup )---
void sendData()
float h = dht.readHumidity();
moisture_val = analogRead(A0); // read the value from the moisture sensor
Blynk.virtualWrite(V2, t);
Blynk.virtualWrite(V1, h);
Blynk.virtualWrite(V3, moisture_val);
if (moisture_val < 850)
led.on();
digitalWrite (Relay_1, HIGH);
led.off();
digitalWrite (Relay_1, LOW);
Now I prepare housing and “put on the field”.
Looks like a fun project, but you are bound to run into trouble with the delays you are using. I’d recommend using SimpleTimer to get your readings
Sorry, you read to fast, I published old version with delays, which really DO a lot of trouble :-). Thanks!
Lol, np, it just caught my eye in between work
you are awesome thank you! i will try it soon.
Costas
September 8, 2016, 7:56am
6
As a big fan of the WeMos D1 Mini and Blynk plus a critic of shields I was drawn to this thread by the title. In my mind the Mini and Blynk are excellent products but shields, in the main, are over priced extras you can do without. That’s coming from someone who can barely hold an iron.
The MCU’s are exceptional value for money (loss leaders?) but some shields are extortionate in comparison.
Enough of my drivel and the real reason for my post.
This is a great example of a bad sketch turned good. If you click the edit button in post 1 you will see the “history” of the sketch, starting with the delays over 14000ms in loop() ! This was the Arduino style sketch and may have been fine on an Arduino but certainly not an ESP with Blynk.
Looking at the revised sketch you can see that the essential SimpleTimer library has been added and it is now ESP and Blynk compliant.
I have saved both versions of the sketch to a single sketch in my sketchbook, called badtogoodsketch.ino.
sorry would you be able to help me?
what is the pin number soil moisture sensor connected to? i see D4 is for DHT 11, relay D1
i am a beginner
moisture_val = analogRead(A0); // read the value from the moisture sensor - it is A0 pin, as moisture is measured as analog value.
Complete working sketch:
#include "ESP8266WiFi.h"
#include "BlynkSimpleEsp8266.h"
#include "DHT.h"
#include "SimpleTimer.h" //Good timer library
int temp;
int humidity;
int moisture_val;
char auth[] = "token "; //Auth Token for project
// Blynk Led Widget
dht.begin();
Blynk.begin(auth, "here your wifi name", "here your wifi password");
//--(end setup )---
void sendData()
if (moisture_val < 750)
led.on();
led.off();
