I have problem with this project. Cant set Wemos D1 mini with sensor SEN01777 to sent data for Blynk server
#define LENG 31 //0x42 + 31 bytes equal to 32 bytes
unsigned char buf[LENG];
static const int RXPin = 3, TXPin = 1;
int PM01Value=0; //define PM1.0 value of the air detector module
int PM2_5Value=0; //define PM2.5 value of the air detector module
int PM10Value=0; //define PM10 value of the air detector module
SoftwareSerial PMSerial(RXPin, TXPin); // RX, TX
// char auth[] = "0ee7c91ad7b7485f821a9d0c89230b91"; // galaxy s8+ blynk auth
// char ssid[] = "911436-2.4G"; // home wifi
// char pass[] = "280446199"; // home pass
char ssid[] = "TEST"; // home wifi
char pass[] = "marcin123"; // home pass
PMSerial.begin(9600);
PMSerial.setTimeout(1500);
Serial.println();
if(PMSerial.find(0x42)){
PMSerial.readBytes(buf,LENG);
if(buf[0] == 0x4d){
if(checkValue(buf,LENG)){
PM01Value=transmitPM01(buf); //count PM1.0 value of the air detector module
PM2_5Value=transmitPM2_5(buf);//count PM2.5 value of the air detector module
PM10Value=transmitPM10(buf); //count PM10 value of the air detector module
static unsigned long OledTimer=millis();
if (millis() - OledTimer >=1000)
OledTimer=millis();
Serial.print("PM1.0: ");
Serial.print(PM01Value);
Serial.println(" ug/m3");
Blynk.virtualWrite(V4, PM01Value); // Display PM1 Value
Serial.print("PM2.5: ");
Serial.print(PM2_5Value);
Blynk.virtualWrite(V5, PM2_5Value); // Display PM2.5 Value
Serial.print("PM1 0: ");
Serial.print(PM10Value);
Serial.println();
Blynk.virtualWrite(V5, PM10Value); // Display PM10 Value
char checkValue(unsigned char *thebuf, char leng)
char receiveflag=0;
int receiveSum=0;
for(int i=0; i<(leng-2); i++){
receiveSum=receiveSum+thebuf[i];
receiveSum=receiveSum + 0x42;
if(receiveSum == ((thebuf[leng-2]<<8)+thebuf[leng-1])) //check the serial data
receiveSum = 0;
receiveflag = 1;
return receiveflag;
int transmitPM01(unsigned char *thebuf)
int PM01Val;
PM01Val=((thebuf[3]<<8) + thebuf[4]); //count PM1.0 value of the air detector module
return PM01Val;
//transmit PM Value to PC
int transmitPM2_5(unsigned char *thebuf)
int PM2_5Val;
PM2_5Val=((thebuf[5]<<8) + thebuf[6]);//count PM2.5 value of the air detector module
return PM2_5Val;
int transmitPM10(unsigned char *thebuf)
int PM10Val;
PM10Val=((thebuf[7]<<8) + thebuf[8]); //count PM10 value of the air detector module
return PM10Val;
