@zackbare3569 is this the joystick sketch you are using as nobody else has reported any problems with it:
You can receive x and y coords for joystick movement within App.
App project setup:
Two Axis Joystick on V1 in MERGE output mode.
MERGE mode means device will receive both x and y within 1 message
char pass[] = "YourPassword";
BLYNK_WRITE(V1) {
int x = param[0].asInt();
int y = param[1].asInt();
// Do something with x and y
Serial.print("X = ");
Serial.print(x);
Serial.print("; Y = ");
Serial.println(y);
Serial.begin(115200); // 9600 in Sketch Builder
I’m using the uploaded code, with Joystick in app to adjust the brightness of an LED
(Note - It worked just fine on different Wemos D1 mini which blew up in an accident)
Actually I pin-pointed it out while using this sketch to transfer data from this board to Uno, via I2C
That’s the problem I cannot ensure the board is faulty, as every other thing I do with it, works just fine.
Even the joystick command runs for a few seconds on Digital pin, but on Virtual pin, it crashes immediately.
thanks, i know how to find the wemos schematic in google. i’ve thought that you should post a basic schematic about YOUR setup, what is hooked up to what pin, etc.
Ooh right the serial debug output, I’m sorry and afraid that I’m too much of a newbie to get that and my setup is use any of the digital pin and put a single LED, and try to dim it with joystick, that’s it.
the serial debug is EASY to view and can be a HUGE help, so it is worth learning:
1 - connect the wemos with the pc usb port via a reasonable quality and not very long (less than 2 meter) usb data cable (like when you are uploading the sketch)
2 - make sure this line is not commented in your sketch:
