Hi there,
I have Wemos D1 mini which checks soil humidity and local temperature and sends data to Blynk. This part of code is doig good job already. Now I decided to add deep sleep functionality to my project.
I faced the following behavior of the board. When you plug usb cable / battery power to the board for the first time, it starts fine, connects to Blynk, do measures and send data to server, disconnects from Blynk and went to sleep. Till that moment everything goes well, but after wake up board can`t connect to Blynk and hangs. Sometime after long hangup Wemos D1 got a crash. Pressing reset button doesnt help, board reach β[xxx] Connecting to MYHOME_WiFiβ and always hangs here.
Please find below copy from COM port monitor:
[4971] Connected to WiFi
[4971] IP: 192.168.1.196
[4971]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.4.8 on Arduino
[4980] Free RAM: 44432
[5001] Connecting to blynk-cloud.com:8442
[5639] <[02|00|01|00] 42a21ec155c640adb7da04f85049ed22
[5854] >[00|00|01|00|C8]
[5854] Ready (ping: 25ms).
[5854] <[11|00|02|00]Hver[00]0.4.8[00]h-beat[00]10[00]buff-in[00]1024[00]dev[00]Arduino[00]build[00]Sep 3 2017 19:55:29[00]
[6055] <[10|00|03|00|05]vr[00]10
[6200] >[00|00|02|00|C8]
Blynk.begin executed...
[6201] <[0E|00|04|00|1B]Hardware is just connected!
[6400] >[00|00|04|00|0E]
[16396] <[06|00|05|00|00]
[18128] >[00|00|05|00|C8]
[28129] <[06|00|06|00|00]
[28192] >[00|00|06|00|C8]
[38192] <[06|00|07|00|00]
[38243] >[00|00|07|00|C8]
[48243] <[06|00|08|00|00]
[48572] >[00|00|08|00|C8]
[50003] >[11|1E]a[00|04]
[50004] >acon
[58572] <[06|00|09|00|00]
[58688] >[00|00|09|00|C8]
Running measurement routine now...
Current humidity value:8
[66795] <[14|00|0A|00|07]vw[00]40[00]8
[66941] <[14|00|0B|00|07]vw[00]45[00]8
ROM = 28 FF DA 9B B3 16 4 A1
Chip = DS18B20
Data = 1 7A 1 4B 46 7F FF C 10 EC CRC=EC
Temperature = 0.00 Celsius, 74.53 Fahrenheit
[68042] <[14|00|0C|00|0C]vw[00]50[00]23.625
[68103] <[14|00|0D|00|0C]vw[00]55[00]23.625
Measurements succesfully done!
Now I'm going to deep sleep for 60 seconds, bye, bye...
[68255] Disconnected
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 1384, room 16
tail 8
chksum 0x2d
csum 0x2d
v3de0c112
~ld
Ρ
Something got me started!
Blynk.begin...
[285] Connecting to MYHOME_WiFi
Exception (29):
epc1=0x4020f9ab epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000019 depc=0x00000000
ctx: sys
sp: 3ffffd00 end: 3fffffb0 offset: 01a0
>>>stack>>>
3ffffea0: 00000001 4022a79f 000002e1 ffffffd3
3ffffeb0: 3ffffed0 4020fabb 3ffed95c 00000009
3ffffec0: 3ffee108 00000001 3ffeec08 00000064
3ffffed0: 00000018 3ffee07c 3ffe9346 3ffe9346
3ffffee0: 3fff1027 3ffe93d4 3fff0c34 0000000b
3ffffef0: 4021165f 3ffee030 3ffee108 49e2f6e6
3fffff00: 00000001 4022bb68 3ffed9e0 401004d8
3fffff10: 40211314 402112e8 3ffee048 00000000
3fffff20: 402130c5 402112e8 17169e46 40226029
3fffff30: 3ffeda40 4021308c 3ffee048 3ffee7a0
3fffff40: 402112de 49e27810 60000600 40226271
3fffff50: 40211285 3ffee048 3ffee7a0 49e2f6e6
3fffff60: 40211738 1716caad 3ffee7a0 60000600
3fffff70: 4021bd89 3ffee048 3ffee7a0 49e2ca70
3fffff80: 4021bdce 3fffdab0 00000000 3fffdcb0
3fffff90: 3ffee7c0 3fffdad0 3ffef298 402056cf
3fffffa0: 40000f49 40000f49 3fffdab0 40000f49
<<<stack<<<
)ΠΠ¬βΉKVΠL β\'ΠΠXΠ»
The code as follows:
// Earth Humidity and Ambient Temperature Sensor.
#define BLYNK_DEBUG // Optional, this enables lots of prints
#include <OneWire.h>
/* Wemos D1 mini pro piouts remark
A0 - A0
D0 - GPIO16 to be coonected to RST to utilise ESP.deepSleep([microseconds]* 1000000, [mode])
D1 - GPIO5
D2 - GPIO4
D3 - GPIO0, Pull-up
D4 - GPIO2, Pull-up, BUILTIN_LED
D5 - GPIO14
D6 - GPIO12
D7 - GPIO13
D8 - GPIO15, Pull-down
bool connected = false;
int WiFi_status = WL_IDLE_STATUS;
#define HUMIDITY_PIN A0 // Humidity pin
#define BUZZER_PIN D1 // BUZZER at pin D1/GPIO5
#define PWR_PIN D5 // Power supply pin for humidity sensor
#define DTEMP_PIN D6 // DS18B20 digital temperature sensor at pin D6/GPIO12
#define BLYNK_HMDTY_PIN V40 // Humidity data display pin to blynk
#define BLYNK_HMDTY_GRAPH_PIN V45 // Humidity data graph pin to blynk
#define BLYNK_DTEMP_PIN V50 // Temperature data display pin to blynk
#define BLYNK_DTEMP_GRAPH_PIN V55 // Humidity data graph pin to blynk
OneWire ds(DTEMP_PIN);
// ΠΌΠΈΠ½ΠΈΠΌΠ°Π»ΡΠ½ΡΠΉ ΠΏΠΎΡΠΎΠ³ Π²Π»Π°ΠΆΠ½ΠΎΡΡΠΈ ΠΏΠΎΡΠ²Ρ
#define HUMIDITY_MIN 200
// ΠΌΠ°ΠΊΡΠΈΠΌΠ°Π»ΡΠ½ΡΠΉ ΠΏΠΎΡΠΎΠ³ Π²Π»Π°ΠΆΠ½ΠΎΡΡΠΈ ΠΏΠΎΡΠ²Ρ
#define HUMIDITY_MAX 700
// ΠΏΠ΅ΡΠ΅ΠΌΠ΅Π½Π½Π°Ρ Π΄Π»Ρ Ρ
ΡΠ°Π½Π΅Π½ΠΈΡ ΠΏΠΎΠΊΠ°Π·Π°Π½ΠΈΡ Π²Π»Π°ΠΆΠ½ΠΎΡΡΠΈ ΠΏΠΎΡΠ²Ρ
unsigned int humidity = 0;
//define Time variable
unsigned long startTime;
unsigned int sleepSeconds = 60; // 60 minutes = 3600 seconds
//define temperature variables
byte i;
byte present = 0;
byte type_s;
byte data[12];
byte addr[8];
float celsiusNow, celsius, fahrenheit;
//Setup Networks credentials
char auth[] = "42a21ec155c640adb7da04f85049ed22"; //iGreenery project
//char ssid[] = "XX_XXXXX";
char ssid[] = "XXXXXX_XXXX";
char pass[] = "XXXX";
//Setup Blynk communications
/*WidgetLED D0_led(V0);
WidgetLED D1_led(V1);
WidgetLED D2_led(V2);
WidgetLED D3_led(V3);
WidgetLED D4_led(V4);
WidgetLED D5_led(V5);
WidgetLED D6_led(V6);
WidgetLED D7_led(V7);
WidgetLED D8_led(V8);
WidgetLCD lcd(V5);
BLYNK_CONNECTED(){
Blynk.syncVirtual(V10); //Sync state of XXXXX button from app.
BLYNK_WRITE(V10) //Xxxxxxx Button Widget is writing to pin V10
// Xxxxxxxv10 = param.asInt(); // assigning incoming value from pin V1 to a variable
BLYNK_WRITE(V15) //Xxxxxxx Button Widget is writing to pin V15
// Xxxxxxxv15 = param.asInt();
BLYNK_WRITE(V20) //Xxxxxxx Button Widget is writing to pin V20
// Xxxxxxxv20 = param.asInt();
BLYNK_WRITE(V25) //Xxxxxxx Button Widget is writing to pin V25
// Xxxxxxxv25 = param.asInt();
BLYNK_WRITE(V30) //Xxxxxxx Button Widget is writing to pin V30
// Xxxxxxxv30 = param.asInt();
// Blynk.virtualWrite(V40, anydata); //How to send any data or function like uptime (millis() / 1000) from hardware to virtual pin in Blynk
// Setup command
unsigned char cmd;
enum Command
CMD_NONE,
//==============================SETUP==============================
void setup(){
Serial.begin(74880);
delay (100);
Serial.println();
Serial.print("Something got me started!");
Serial.println();
// command initialisation (no command yet)
cmd = CMD_NONE;
pinMode(PWR_PIN, OUTPUT);
pinMode(D0, WAKEUP_PULLUP);
delay(100);
Serial.print("Blynk.begin...");
Serial.println();
Serial.print("Blynk.begin executed...");
Serial.println();
Blynk.notify("Hardware is just connected!");
// trigger sendData function above every x seconds
timer.setInterval(60000, Measure_Send_Routine); // 10000 = 10 seconds (x/1000=seconds)
//==========================END OF SETUP==============================
void Measure_Send_Routine(){
Serial.print("Running measurement routine now...");
Serial.println();
// ===================Measure Humidity here===================
// Power up humidity sensor
digitalWrite(PWR_PIN, HIGH);
delay (200);
// ΡΡΠΈΡΡΠ²Π°Π΅ΠΌ ΡΠ΅ΠΊΡΡΠ΅Π΅ ΠΏΠΎΠΊΠ°Π·Π°Π½ΠΈΡ Π΄Π°ΡΡΠΈΠΊΠ° Π²Π»Π°ΠΆΠ½ΠΎΡΡΠΈ ΠΏΠΎΡΠ²Ρ
String serialMessage = "Current humidity value:";
int humidityNow = analogRead(HUMIDITY_PIN);
// Power down of humidity sensor
digitalWrite(PWR_PIN, LOW);
delay (200);
// Π΅ΡΠ»ΠΈ ΠΏΠΎΠΊΠ°Π·Π°Π½ΠΈΡ ΡΠ΅ΠΊΡΡΠ΅ΠΉ Π²Π»Π°ΠΆΠ½ΠΎΡΡΠΈ ΠΏΠΎΡΠ²Ρ
// Π½Π΅ ΡΠ°Π²Π½ΡΠ΅ΡΡΡ ΠΏΡΠ΅Π΄ΡΠ΄ΡΡΠ΅ΠΌΡ Π·Π°ΠΏΡΠΎΡΡ
if(humidityNow != humidity) {
// ΡΠΎΡ
ΡΠ°Π½ΡΠ΅ΠΌ ΡΠ΅ΠΊΡΡΠΈΠ΅ ΠΏΠΎΠΊΠ°Π·Π°Π½ΠΈΡ Π²Π»Π°ΠΆΠ½ΠΎΡΡΠΈ
humidity= humidityNow;
Serial.print(serialMessage += humidity);
Serial.println();
// ΠΈ ΠΎΡΠΏΡΠ°Π²Π»ΡΠ΅ΠΌ ΠΏΠΎΠΊΠ°Π·Π°Π½ΠΈΡ Π²Π»Π°ΠΆΠ½ΠΎΡΡΠΈ Π½Π° BLYNK_HMDTY_PIN ΠΈ ΠΏΠΎ e-mail
Blynk.virtualWrite(BLYNK_HMDTY_PIN, humidity);
Blynk.virtualWrite(BLYNK_HMDTY_GRAPH_PIN, humidity);
//Blynk.email("motorola_inside@mail.ru", "Subject:Earth humidity is changed to", humidity );
// ===================Measure Temperature here================
if ( !ds.search(addr)) {
Serial.println("Error: No more addresses.");
Serial.println();
ds.reset_search();
delay(250);
Serial.printf("I'm going to deep sleep anyway for %d seconds, bye, bye...\n\n", sleepSeconds);
Blynk.disconnect();
delay (300);
ESP.deepSleep(sleepSeconds * 1000000, WAKE_RF_DISABLED);
return;
Serial.print("ROM =");
for( i = 0; i < 8; i++) {
Serial.write(' ');
Serial.print(addr[i], HEX);
if (OneWire::crc8(addr, 7) != addr[7]) {
Serial.println("CRC is not valid!");
return;
Serial.println();
// ΠΏΠ΅ΡΠ²ΡΠΉ Π±Π°ΠΉΡ ΠΎΠΏΡΠ΅Π΄Π΅Π»ΡΠ΅Ρ ΡΠΈΠΏ
switch (addr[0]) {
case 0x10:
Serial.println(" Chip = DS18S20"); // ΠΈΠ»ΠΈ Π±ΠΎΠ»Π΅Π΅ ΡΡΠ°ΡΡΠΉ DS1820
type_s = 1;
break;
case 0x28:
Serial.println(" Chip = DS18B20");
type_s = 0;
break;
case 0x22:
Serial.println(" Chip = DS1822");
type_s = 0;
break;
default:
Serial.println("Device is not a DS18x20 family device.");
return;
ds.reset();
ds.select(addr);
ds.write(0x44); // Π½Π°ΡΠΈΠ½Π°Π΅ΠΌ ΠΏΡΠ΅ΠΎΠ±ΡΠ°Π·ΠΎΠ²Π°Π½ΠΈΠ΅, ΠΈΡΠΏΠΎΠ»ΡΠ·ΡΡ ds.write(0x44,1) Ρ "ΠΏΠ°ΡΠ°Π·ΠΈΡΠ½ΡΠΌ" ΠΏΠΈΡΠ°Π½ΠΈΠ΅ΠΌ
delay(1000); // 750 ΠΌΠΎΠΆΠ΅Ρ Π±ΡΡΡ Π΄ΠΎΡΡΠ°ΡΠΎΡΠ½ΠΎ, Π° ΠΌΠΎΠΆΠ΅Ρ Π±ΡΡΡ ΠΈ Π½Π΅ Ρ
Π²Π°ΡΠΈΡ
// ΠΌΡ ΠΌΠΎΠ³Π»ΠΈ Π±Ρ ΠΈΡΠΏΠΎΠ»ΡΠ·ΠΎΠ²Π°ΡΡ ΡΡΡ ds.depower(), Π½ΠΎ reset ΠΏΠΎΠ·Π°Π±ΠΎΡΠΈΡΡΡ ΠΎΠ± ΡΡΠΎΠΌ
present = ds.reset();
ds.select(addr);
ds.write(0xBE);
Serial.print(" Data = ");
Serial.print(present, HEX);
Serial.print(" ");
for ( i = 0; i < 9; i++) { // Π½Π°ΠΌ Π½Π΅ΠΎΠ±Ρ
ΠΎΠ΄ΠΈΠΌΠΎ 9 Π±Π°ΠΉΡ
data[i] = ds.read();
Serial.print(data[i], HEX);
Serial.print(" ");
Serial.print(" CRC=");
Serial.print(OneWire::crc8(data, 8), HEX);
Serial.println();
// ΠΊΠΎΠ½Π²Π΅ΡΡΠΈΡΡΠ΅ΠΌ Π΄Π°Π½Π½ΡΠΉ Π² ΡΠ°ΠΊΡΠΈΡΠ΅ΡΠΊΡΡ ΡΠ΅ΠΌΠΏΠ΅ΡΠ°ΡΡΡΡ
// ΡΠ°ΠΊ ΠΊΠ°ΠΊ ΡΠ΅Π·ΡΠ»ΡΡΠ°Ρ ΡΠ²Π»ΡΠ΅ΡΡΡ 16 Π±ΠΈΡΠ½ΡΠΌ ΡΠ΅Π»ΡΠΌ, Π΅Π³ΠΎ Π½Π°Π΄ΠΎ Ρ
ΡΠ°Π½ΠΈΡΡ Π²
// ΠΏΠ΅ΡΠ΅ΠΌΠ΅Π½Π½ΠΎΠΉ Ρ ΡΠΈΠΏΠΎΠΌ Π΄Π°Π½Π½ΡΡ
"int16_t", ΠΊΠΎΡΠΎΡΠ°Ρ Π²ΡΠ΅Π³Π΄Π° ΡΠ°Π²Π½Π° 16 Π±ΠΈΡΠ°ΠΌ,
// Π΄Π°ΠΆΠ΅ Π΅ΡΠ»ΠΈ ΠΌΡ ΠΏΡΠΎΠ²ΠΎΠ΄ΠΈΠΌ ΠΊΠΎΠΌΠΏΠΈΠ»ΡΡΠΈΡ Π½Π° 32-Ρ
Π±ΠΈΡΠ½ΠΎΠΌ ΠΏΡΠΎΡΠ΅ΡΡΠΎΡΠ΅
int16_t raw = (data[1] << 8) | data[0];
if (type_s) {
raw = raw << 3; // ΡΠ°Π·ΡΠ΅ΡΠ΅Π½ΠΈΠ΅ 9 Π±ΠΈΡ ΠΏΠΎ ΡΠΌΠΎΠ»ΡΠ°Π½ΠΈΡ
if (data[7] == 0x10) {
raw = (raw & 0xFFF0) + 12 - data[6];
byte cfg = (data[4] & 0x60);
// ΠΏΡΠΈ ΠΌΠ°Π»Π΅Π½ΡΠΊΠΈΡ
Π·Π½Π°ΡΠ΅Π½ΠΈΡΡ
, ΠΌΠ°Π»ΡΠ΅ Π±ΠΈΡΡ Π½Π΅ ΠΎΠΏΡΠ΅Π΄Π΅Π»Π΅Π½Ρ, Π΄Π°Π²Π°ΠΉΡΠ΅ ΠΈΡ
ΠΎΠ±Π½ΡΠ»ΠΈΠΌ
if (cfg == 0x00) raw = raw & ~7; // ΡΠ°Π·ΡΠ΅ΡΠ΅Π½ΠΈΠ΅ 9 Π±ΠΈΡ, 93.75 ΠΌΡ
else if (cfg == 0x20) raw = raw & ~3; // ΡΠ°Π·ΡΠ΅ΡΠ΅Π½ΠΈΠ΅ 10 Π±ΠΈΡ, 187.5 ΠΌΡ
else if (cfg == 0x40) raw = raw & ~1; // ΡΠ°Π·ΡΠ΅ΡΠ΅Π½ΠΈΠ΅ 11 Π±ΠΈΡ, 375 ΠΌΡ
//// ΡΠ°Π·ΡΠ΅ΡΠ΅Π½ΠΈΠ΅ ΠΏΠΎ ΡΠΌΠΎΠ»ΡΠ°Π½ΠΈΡ ΡΠ°Π²Π½ΠΎ 12 Π±ΠΈΡ, Π²ΡΠ΅ΠΌΡ ΠΏΡΠ΅ΠΎΠ±ΡΠ°Π·ΠΎΠ²Π°Π½ΠΈΡ - 750 ΠΌΡ
celsiusNow = (float)raw / 16.0;
fahrenheit = celsiusNow * 1.8 + 32.0;
Serial.print(" Temperature = ");
Serial.print(celsius);
Serial.print(" Celsius, ");
Serial.print(fahrenheit);
Serial.println(" Fahrenheit");
if(celsiusNow != celsius) {
// ΡΠΎΡ
ΡΠ°Π½ΡΠ΅ΠΌ ΡΠ΅ΠΊΡΡΠΈΠ΅ ΠΏΠΎΠΊΠ°Π·Π°Π½ΠΈΡ ΡΠ΅ΠΌΠΏΠ΅ΡΠ°ΡΡΡΡ
celsius= celsiusNow;
// ΠΈ ΠΎΡΠΏΡΠ°Π²Π»ΡΠ΅ΠΌ ΠΏΠΎΠΊΠ°Π·Π°Π½ΠΈΡ ΡΠ΅ΠΌΠΏΠ΅ΡΠ°ΡΡΡΡ Π½Π° BLYNK_DTEMP_PIN ΠΈ Π½Π° e-mail
Blynk.virtualWrite(BLYNK_DTEMP_PIN, celsius);
Blynk.virtualWrite(BLYNK_DTEMP_GRAPH_PIN, celsius);
//Blynk.email("motorola_inside@mail.ru", "Subject:Temperature in Greenery is changed to", celsius);
delay(100);
Serial.println("Measurements succesfully done!");
Serial.printf("Now I'm going to deep sleep for %d seconds, bye, bye...\n\n", sleepSeconds);
Blynk.disconnect();
delay (300);
I would appreciate your help.
