Wemos D1 + Blynk + Arduino IDE (Dont Work)
Hi , this is my code.
#define BLYNK_TEMPLATE_ID “”
#define BLYNK_DEVICE_NAME “Wemos Living”
#define BLYNK_AUTH_TOKEN “”
char ssid[] = "Jarvis Modem";
char pass[] = "";
const int timbre = D2;
const int btntimbre = D6;
const int btnluz = D4;
const int luzliving = D1;
const int luzgarage = D8;
int estadotimbre = LOW;
int estadobtntimbre = LOW;
int estadobtnluz = LOW;
int estadoluzliving = LOW;
int estadoluzgarage = LOW;
BLYNK_WRITE(V1) {
  estadoluzliving = param.asInt();
  digitalWrite(luzliving, estadoluzliving);
  Blynk.virtualWrite(V1, estadoluzliving);
BLYNK_WRITE(V2) {
  estadoluzgarage = param.asInt();
  digitalWrite(luzgarage, estadoluzgarage);
  Blynk.virtualWrite(V2, estadoluzgarage);
  pinMode(luzliving, OUTPUT);
  pinMode(luzgarage, OUTPUT);
  pinMode(timbre, OUTPUT);
  pinMode(btntimbre, INPUT_PULLUP);
  pinMode(btnluz, INPUT_PULLUP);
  Serial.print("Sistema Iniciado");
  timer.setInterval(100L, checkearbotontimbre);
  timer.setInterval(200L, checkearbotonluzliving);
void checkearbotontimbre()
  if (digitalRead(btntimbre) == LOW) {
    if (estadobtntimbre != LOW) {
      Serial.print("LOOOOOOW");
      Serial.println();
      SonarTimbre();
      Blynk.notify("[CASA] Alguien toco el timbre.");
    estadobtntimbre = HIGH;
void checkearbotonluzliving()
  if (digitalRead(btnluz) == LOW) {
    if (estadobtnluz != LOW) {
      estadoluzliving = !estadoluzliving;
      Blynk.virtualWrite(V2, estadoluzliving);
    estadobtnluz = LOW;
    estadobtnluz = HIGH;
void SonarTimbre()
  digitalWrite(timbre, LOW);
  Serial.print("Timbre Encendido");
  Serial.println();
  timer.setTimeout(2000L, ApagarTimbre);  // Run ActionOFF function in 5 seconds
void ApagarTimbre()
  Serial.print("Timbre Apagado");
  Serial.println();
  estadobtntimbre = !estadobtntimbre;
I have problems for upload idk what board need to use for work…
idk if my wemos is D1 or D2… I just similar to arduino UNO. (size)
imagen
The problem is when i upload with imagen
Serial prints working but relay (outputs) dont work…
When i upload with imagen
Relay Works but Serial Prints dont work…
idk what happend i dont find doc about this…
I just need 4 outputs and 2 inputs idk what board really need for buy.
Thx for all hlep!
Some photos of your board would help.
It sounds like maybe you’re connecting the relays to the wrong pins.
There is, sorry about double post but cant reply with photos only idk why.
That’s a D1 R1
Make sure you use the PIN numbers in red on this diagram when you’re connecting-up your relays…
Yes i use red pins, but idk what happend with 3 boards same issue, my code its ok ?
Code working correct when i put D6 to GND show me this in console.
That’s your serial monitor.
You’d be far better copying and pasting the contents of your serial monitor than posting a screenshot.
[4297] Connected to WiFi
[4297] IP: 192.168.1.122
[4297]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ / '/
//_, /////_
__/ v1.0.1 on ESP8266
[4374] Connecting to blynk.cloud:80
[4770] Ready (ping: 158ms).
Sistema IniciadoLOOOOOOW
Timbre Encendido
LOOOOOOW
Timbre Encendido
Timbre Apagado
LOOOOOOW
Timbre Encendido
Timbre Apagado
LOOOOOOW
Timbre Encendido
Timbre Apagado
LOOOOOOW
Timbre Encendido
Timbre Apagado
LOOOOOOW
Timbre Encendido
Timbre Apagado
Timbre Apagado
LOOOOOOW
Timbre Encendido
Timbre Apagado
LOOOOOOW
Timbre Encendido
Timbre Apagado
Hi Kevin
Try use for output D1, D2 , D7 and D0, D4, D5 for input
Do not use D8 at all
/Torben
This is the WeMos D1 pin mapping
#define BLYNK_TEMPLATE_ID           ""
#define BLYNK_DEVICE_NAME           "Wemos Living"
#define BLYNK_AUTH_TOKEN            ""
char pass[] = "";
const int timbre = D7;
const int btntimbre = D5;
      Serial.println();
      SonarTimbre();
void SonarTimbre()
  Serial.println();
void ApagarTimbre()
  Serial.println();
Not working… i test with 4 wemos idk what happend.Change Wires, change Relays , change USB cable i think the problem is the selected board in arduino or the code its not ok.
We don’t know either, because you’re not providing information to us about how your hardware is actually connected to your board (in the form of a schematic), how your relays are powered and whether they are active LOW or active HIGH relays.
You also havent elaborated on what this statement means…
mmm sorry about my english, im from argentina.
Wemos powered with PIN 12V 2A. 4 Relays Modules Poweres with Wemos (Working if i put simple code with virtual pins. Example if i put datastream V1 and BLYNK_WRITE(V1) with digitalWrite to Relays Working Perfect)
But when i use my code for read Physycall button dont work.
4 MODULE RELAY ------- WEMOS
GND ------- GND
VCC ------- 5v
RELAY1 ------- D2
Button with with GND for check physicall button its conected to D4. When i give GND to D4 Serial Prints (Funcionts Working Perfect but relay dont work)
@EscuderoKevin You would like to control the relay using the app and a button, am I right ?
Your code is checking pin D5
Yep, Control 2 Relays.
When physical button pushed ON RELAY 1 , 5 SECONDS LATER STOP RELAY 1.
When 2cond physical button pushed ON RELAY 2. When pushed agian OFF RELAY 2. (This code is simple)
    // When App button is pushed - switch the state
BLYNK_WRITE(V2) {
  ledState = param.asInt();
  digitalWrite(ledPin, ledState);
void checkPhysicalButton()
  if (digitalRead(btnPin) == LOW) {
    if (btnState != LOW) {
      // Toggle LED state
      ledState = !ledState;
      // Update Button Widget
      Blynk.virtualWrite(V2, ledState);
    btnState = LOW;
    btnState = HIGH;
Relay 1 its only controlled with physical button.
Relay 2 its controlled with physical button and App.
Yes i see that but i conected correct.
Please post a schematic, which matches your actual hardware wiring setup.
First, you can try this example : Blynk Example Browser
Second, blynk.notify has been replaced with blynk.logevent, check this out
https://docs.blynk.io/en/getting-started/events-tutorial
