• Hardware model: Wemos D1 mini (wifi)
• Android 9, web blynk.cloud
• Blynk server
• Blynk Library version v1.0.1 (github latest)
I can see timer is working by observing the blinking LED.
However, no messages appear in Serial monitor after Blynk is connected to wifi.
In blynk.cloud I see the metadata is updated, device is marked Online, but no sensor data or events are displayed.
Also without Blynk.begin
and Blynk.run
sensors work and I can see reports in Serial monitor.
Please help.
START
11:37:33.565 -> [103] Connecting to shu_****
11:37:37.773 -> [4333] Connected to WiFi
11:37:37.773 -> [4333] IP: 192.168.99.140
11:37:37.773 -> ___ __ __
11:37:37.807 -> / _ )/ /_ _____ / /__
11:37:37.807 -> / _ / / // / _ \/ '_/
11:37:37.807 -> /____/_/\_, /_//_/_/\_\
11:37:37.807 -> /___/ v1.0.0-beta.1 on ESP8266
11:37:37.807 ->
11:37:37.807 -> [4340] Connecting to blynk.cloud:80
11:37:37.912 -> [4443]
Sketch:
#define BLYNK_TEMPLATE_ID "*****"
#define BLYNK_DEVICE_NAME "Garage Temperature and Smoke Sensor ESP8266"
#define BLYNK_AUTH_TOKEN "*****"
#include <OneWire.h>
#define SMOKE_PIN D2
#define TEMP_PIN D1
char ssid[] = "shu****";
char pass[] = "****";
long current = 0L;
long lastDhtCheck = 0L;
long lastSmokeCheck = 0L;
int CHECK_INTERVAL = 60*60*1000;
BlynkTimer myTimer;
OneWire oneWire(TEMP_PIN);
float Celcius = 0;
float Fahrenheit = 0;
int ledVal = LOW;
void tempEvent()
Celcius = sensors.getTempCByIndex(0);
Blynk.virtualWrite(V1, Celcius);
Serial.println("Temperature" + (String) Celcius);
if (Celcius > 60) {
Blynk.logEvent("temperature_rising", "3D printer Temp " + (String)Celcius);
void smokeEvent() {
Blynk.logEvent("TEST", "The test");
digitalWrite(LED_BUILTIN, ledVal);
ledVal = !ledVal;
Serial.println("Loop");
int smokePresent = digitalRead(SMOKE_PIN);
Serial.println("Smoke detector " + (String) smokePresent);
if (smokePresent == LOW) {
Blynk.logEvent("smoke", "SMOKE");
Serial.println("SMOKE detected");
Blynk.virtualWrite(V3, smokePresent);
pinMode(SMOKE_PIN, INPUT_PULLUP);
pinMode(LED_BUILTIN, OUTPUT);
Serial.println("START");
sensors.begin();
myTimer.setInterval(1*1000L, smokeEvent);
myTimer.setInterval(60*1000L, tempEvent);
tempEvent();
smokeEvent();
myTimer.run();
