WebPage BUTTON
I created 2 pieces of WebPage button. (1x http://192.168.0.214/cm?cmnd=Power%20On and 1x http://192.168.0.214/cm?cmnd=Power%20Off) That also works.
But what bothers me is that every time a new website is opened. Can you prevent that?
Wouldn’t you be better using the Webhook widget for this?
No. I use Shelly 1 to switch. How should that work then?
You can switch this very well with http commands.
And the Webhook widget is used to send HTTP (or HTTPS) commands to devices. This would normally be an external server,but could just as easily be an internal device such as the Shelly1
Or, you could just re-flash your Shelly1 with your own Blynk sketch and control it that way - much neater in the end.
