Web Dashboard Chart Not Ploting Multiple Datastreams
I am using the web dashboard (NY3), Chrome (155.0.8059.39), and getting data through notehub.io. I created several charts with 3 multiple datastreams, but the chart only ever plots the first
To show there is data from the other datastreams, I created individual charts of each datastream, and they plot. Unfortunately I can’t upload more that one photo as someone new…
If I click on the datastream name in the label to turn it off in the chart, the chart just shows no data, even though the two other datastreams are still enabled.
Here are the two other datastreams ploted individually
Could you try Edit Chart > Move Source to put one of the missing datastreams first? Does it then plot while the former first stream disappears? That would help separate a datastream-specific problem from a chart-position problem.
The reordering option is documented here: Chart | Blynk Documentation
No it doesn’t seem to be the ordering. Whatever is the first datastream is the only one that plots. Here is a screenshot of the two flipped. Also the now second datastream shows up in the second chart when it is the only datastream.
Sometimes if I switch to live mode (vs 1week), it shows some data from the second, but only after a couple minutes (I think after blynk receives a new reading from my sensor)
