I was looking at Blynk Console Datastreams on device that I have spare integer points defined. These points are not defined nor used in the actual device, just spares.
I was surprised to see that the property values were updating. Further investigation showed the property values are actually from another device. I did check on multiple browsers and the problem was consistent.
device1 screen capture
After screen reload the initial property values are correct :
Then after the device2 updates. device1 now shows incorrect property values:
device2 screen capture
And the property values from the other device :
Same times, same labels - the pin values are unaffected.
Very confusing for awhile until I realized what I was seeing. A screen refresh shows the correct data, but the after next update, the problem is back!
