Hello!
I’m creating a project to measure speed with NodeMCU Esp8266 and Neo 6M GPS module. It works perfectly before I use GPS Streaming widget. I want to compare the speed from GPS module and the speed from gps on my phone. I’m using GPS Streaming widget to get gps speed from my phone. Here is my code:
#include <TinyGPS++.h>
#include <BlynkSimpleEsp8266_SSL.h>
static const int RXPin = 12, TXPin = 13;
static const uint32_t GPSBaud = 9600;
char auth[] = "#############";
char ssid[] = "##############";
char pass[] = "#############";
TinyGPSPlus gps;
SoftwareSerial ss(RXPin, TXPin);
ss.begin(GPSBaud);
timer.setInterval(500L, check_module);
if (ss.available() > 0)
if (gps.encode(ss.read()))
if (millis() > 5000 && gps.charsProcessed() < 10)
Serial.println(F("No GPS detected: check wiring."));
void check_module()
if (gps.speed.isUpdated())
displayInfo();
void displayInfo()
if (gps.location.isValid())
double gps_spd = trunc(gps.speed.kmph());
String gps_spdbuf;
gps_spdbuf = String(gps_spd);
WidgetLED led1(V1);
WidgetLED led2(V2);
WidgetLED led3(V3);
Serial.print(gps_spdbuf);
Serial.println(" km/h");
Blynk.virtualWrite(V0, gps_spd);
if (gps_spd < 40)
Blynk.setProperty(V0, "color", "#2ecc71");
led1.on();
led2.off();
led3.off();
else if (gps_spd >= 40 && gps_spd <60)
Blynk.setProperty(V0, "color", "#f1c40f");
led1.off();
led2.on();
led3.off();
else if (gps_spd > 60)
Blynk.setProperty(V0, "color", "#e74c3c");
led1.off();
led2.off();
led3.on();
Blynk.notify("Do not exceed speed limit!");
Blynk.email("#######@gmail.com", "Warning!", "Do not exceed speed limit!");
BLYNK_WRITE(V4)
float gps_phone_spd = trunc(param[3].asFloat());
Blynk.virtualWrite(V5, gps_phone_spd);
Serial.println(gps_phone_spd);
I think the problem is Blynk.virtualWrite(V5, gps_phone_spd);
When I erase that, the app works fine without wdt reset. But how can i manage that? I need to compare both speed to SuperChart widget which taking data from V5. Please help!
