Wdt reset problem on nodemcu
so im trying to control some relays on with blynk, ifttt and google assistant, i can easily turn the led im using to test it on, but if i try to turn it off, ifttt says that my applet succesfully ran, and google assistant replies with my programmed response, but the led doesnt turn off, the the serial monitor says
 “ ets Jan 8 2013,rst cause:4, boot mode:(1,6),
wdt reset”
after that, it disconnects from my wifi
whats the problem and how do i solve it?
ive seen a smilar issue with wdt reset and tried the solution but it didnt work
error on serial monitor:
[18987] Connecting to Pheonix
[20991] Connected to WiFi
[20991] IP: 192.168.43.229
[20991]
    ___  __          __
   / _ )/ /_ _____  / /__
  / _  / / // / _ \/  '_/
 /____/_/\_, /_//_/_/\_\
        /___/ v0.5.4 on NodeMCU
[20998] Connecting to blynk-cloud.com:80
[23978] Ready (ping: 99ms).
wdt reset
code :
char auth[] = "2c46ce6488aa46f18cdafda68b0d8130";
char ssid[] = "Pheonix";
char pass[] = "bananatomatobigshark";
  //wdt solve
  ESP.wdtDisable();
  ESP.wdtEnable(WDTO_8S);
  ESP.wdtFeed();
Here is a good read about the WDT
thanks, also do you happen to know some article about how to get started to write event based?
it would be a big help
There is a slew of them in the Help Center…
