Before creating the topic
- Search forum for similar topics
- Check https://docs.blynk.io
- Add details :
• Server you are connected to
• Blynk Library version
• Add your sketch code.
Code should be formatted as example below.
Soft WDT reset
Exception (4):
epc1=0x4000dd24 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
>>>stack>>>
ctx: cont
sp: 3ffffde0 end: 3fffffd0 offset: 0160
3fffff40: 3ffeeda0 00000000 3ffeeda0 402019fd
3fffff50: 00000000 0093a0ed 3ffeeda0 002bb2b4
3fffff60: 3ffeeda0 0000008c 3ffeee34 00001b53
3fffff70: 3ffeeda0 3ffeeb28 00000000 40201f73
3fffff80: 402082e0 1d01a8c0 feefeffe feefeffe
3fffff90: 3ffe89df feefeffe feefeffe feefeffe
3fffffa0: feefeffe feefeffe feefeffe 3ffeefbc
3fffffb0: 3fffdad0 00000000 3ffeef90 40204f44
3fffffc0: feefeffe feefeffe 3fffdab0 40100d95
<<<stack<<<
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
qui peut me dire comment résoudre ce problème. Merci.
