Hi.
I need some help with my Boiler thermostat project. I am quite new to programming but not a complete beginner.
I am using a ESP-01 module, DS18B20 Temp sensor and relay. (Blynk server)
The code I’m using I got from the net and it switch a relay with a Blynk input timer and 2 Blynk buttons, Auto(Timer) and Manual. I modified the code to show Temperature data from the DS18B20 sensor. The code works with Temp data and I can switch the relay with max and min Temperatures. My problem is that if the Temperature switch the relay then I can not use the buttons coz the Temperature holds the relay.
What I want it to do is if I switch the relay manually, or auto with timer, and the Boiler gets to the Max Temp it should switch off, but I also want the manual button to still switch the relay manually so that I can switch off the boiler completely. I want the Max Temp only to be like a safety switch so that the boiler does not go over the set threshold. Here is my code and in lines 90 to 101 is the sendTemps function for the Temp sensor.
#include <EEPROM.h>
#include <OneWire.h>
#include <TimeLib.h>
#include <WidgetRTC.h>
#define EEPROM_STATE_ADDRESS_1 128
#define EEPROM_STATE_ADDRESS_2 144
#define relayLed 2
#define relayPin 0
#define SimpleTimer BlynkTimer
float temp = 0.0;
float maxTemp = 28;
float minTemp = 26;
int oneWireBus = 2;
int geyserTemp;
OneWire oneWire(oneWireBus);
WidgetRTC rtc;
WidgetTerminal terminal(V3);
WidgetLED led1(V4);
WidgetLED led2(V5);
char Date[16];
char Time[16];
char auth[] = "";
char ssid[] = "";
char pass[] = "";
long startsecondswd;
long stopsecondswd;
long nowseconds;
bool isFirstConnect = true;
String displaycurrenttimepluswifi;
int wifisignal;
int manual = 0;
int oldstatus;
int automode;
char ledstate = 0;
char schestate = 0;
bool check = true;
bool check2 = true;
bool check3 = true;
pinMode(relayLed, OUTPUT);
pinMode(relayPin, OUTPUT);
digitalWrite(relayLed, LOW); // set LED OFF
Serial.println("Starting");
int mytimeout = millis() / 1000;
while (Blynk.connect() == false) { // try to connect to server for 10 seconds
if ((millis() / 1000) >
mytimeout + 8) { // try local server if not connected within 9 seconds
break;
sensors.begin();
sensors.setResolution(10);
EEPROM.begin(512);
ledstate = EEPROM.read(EEPROM_STATE_ADDRESS_1) == 1 ? 1 : 0;
schestate = EEPROM.read(EEPROM_STATE_ADDRESS_2) == 1 ? 1 : 0;
ledonstart();
rtc.begin();
timer.setInterval(
10000L,
activetoday); // check every 10 SECONDS if schedule should run today
timer.setInterval(
30000L, reconnectBlynk); // check every 30s if still connected to server
timer.setInterval(5000L, clockvalue); // check value for time
timer.setInterval(5000L, sendWifi); // Wi-Fi singal
timer.setInterval(1000L, check_status);
timer.setInterval(1000L, check_sche);
timer.setInterval(1000L, sendTemps);
void sendTemps() {
geyserTemp = sensors.getTempCByIndex(0);
Blynk.virtualWrite(1, geyserTemp);
/*if (geyserTemp <= minTemp) {
digitalWrite(relayPin, HIGH);
if (geyserTemp >= maxTemp) {
digitalWrite(relayPin, LOW);
void ledonstart() {
if (ledstate == 1) {
digitalWrite(relayLed, 1);
Blynk.virtualWrite(V2, 1);
digitalWrite(relayLed, 0);
Blynk.virtualWrite(V2, 0);
if (schestate == 1) {
Blynk.virtualWrite(V11, 1);
led1.on();
led2.off();
if ((schestate == 1) && (check3 == true)) {
timer.setTimeout(50, resetTerminal);
timer.setTimeout(50, checklastbuttonpressed);
automode = 1;
schestate = 1;
check3 = false;
Blynk.virtualWrite(V11, 0);
led1.off();
led2.on();
void check_status() {
if (digitalRead(relayLed) == HIGH) {
ledstate = 1;
if (check == true) {
EEPROM.write(EEPROM_STATE_ADDRESS_1, ledstate);
EEPROM.commit();
Serial.println("EEPROM Write ledstate ON 1");
check = false;
ledstate = 0;
if (check == false) {
EEPROM.commit();
Serial.println("EEPROM Write ledstate OFF 1");
check = true;
void check_sche() {
if (automode == 1) {
schestate = 1;
if (check2 == true) {
EEPROM.write(EEPROM_STATE_ADDRESS_2, schestate);
EEPROM.commit();
Serial.println("EEPROM Write schestate ON 1");
led1.on();
led2.off();
check2 = false;
schestate = 0;
if (check2 == false) {
EEPROM.commit();
Serial.println("EEPROM Write schestate OFF 1");
led1.off();
led2.on();
check2 = true;
BLYNK_CONNECTED() {
if (isFirstConnect) {
Blynk.syncAll();
Blynk.notify("TIMER STARTING!!!!");
isFirstConnect = false;
void sendWifi() { wifisignal = map(WiFi.RSSI(), -105, -40, 0, 100); }
void clockvalue() // Digital clock display of the time
int gmthour = hour();
if (gmthour == 24) {
gmthour = 0;
String displayhour = String(gmthour, DEC);
int hourdigits = displayhour.length();
if (hourdigits == 1) {
displayhour = "0" + displayhour;
String displayminute = String(minute(), DEC);
int minutedigits = displayminute.length();
if (minutedigits == 1) {
displayminute = "0" + displayminute;
displaycurrenttimepluswifi =
" Clock: " + displayhour + ":" +
displayminute + " Signal: " + wifisignal + " %";
Blynk.setProperty(V3, "label", displaycurrenttimepluswifi);
void activetoday() { // check if schedule should run today
if (year() != 1970) {
Blynk.syncVirtual(V10); // sync timeinput widget
void checklastbuttonpressed() {
oldstatus = 1; // 5
oldstatus = 2; // 6
void restorelastbuttonpressed() {
if (oldstatus == 1) {
automode = 1;
automode = 0;
void resetTerminal() {
terminal.println();
terminal.println();
terminal.println();
terminal.println("AUTO Mode has been selected");
terminal.println("Wait for update (10 seconds as maximum)");
terminal.println();
terminal.println();
terminal.println();
terminal.flush();
BLYNK_WRITE(V2) // ON-OFF Manual
if (param.asInt() == 1) { // boton encendido
terminal.println();
terminal.println();
terminal.println();
terminal.println("Manual MODE is ON");
terminal.println("Press ON/OFF button if required");
terminal.println("Device is ON");
terminal.println();
terminal.println();
terminal.flush();
if (manual == 0) { // está en modo automático
checklastbuttonpressed();
manual = 1;
automode = 0;
digitalWrite(relayLed, HIGH); // set LED ON
digitalWrite(relayPin, HIGH); // set relay ON
Blynk.virtualWrite(V2, 1); // Turn ON Button Widget
}else { // está en modo manual
automode = 0;
digitalWrite(relayPin, HIGH); // set raly ON
terminal.println();
terminal.println();
terminal.println();
terminal.println("Device is OFF");
terminal.println();
terminal.println();
terminal.flush();
if (manual == 0) { // modo automático
manual = 1;
automode = 0;
digitalWrite(relayPin, LOW); // set relay OFF
Blynk.virtualWrite(V2, 0); // Turn OFF Button Widge
automode = 0;
Blynk.virtualWrite(V2, 0); // Turn OFF Button Widget
BLYNK_WRITE(V11) // Up to you selected
automode = 1;
schestate = 1;
automode = 0;
schestate = 0;
BLYNK_WRITE(V10) // Up to you
sprintf(Date, "%02d/%02d/%04d", day(), month(), year());
TimeInputParam t(param);
terminal.print("Auto Mode Checked schedule at: ");
terminal.println(Time);
terminal.flush();
int dayadjustment = -1;
if (weekday() == 1) {
dayadjustment =
6; // needed for Sunday, Time library is day 1 and Blynk is day 7
if (t.isWeekdaySelected(weekday() +
dayadjustment)) { // Time library starts week on
// Sunday, Blynk on Monday
terminal.println("Auto Mode ACTIVE today");
terminal.flush();
if (t.hasStartTime()) // Process start time
terminal.println(String("Start: ") + t.getStartHour() + ":" +
t.getStartMinute());
terminal.flush();
if (t.hasStopTime()) // Process stop time
terminal.println(String("Stop : ") + t.getStopHour() + ":" +
t.getStopMinute());
terminal.flush();
// Display timezone details, for information purposes only
terminal.println(
String("Time zone: ") +
t.getTZ()); // Timezone is already added to start/stop time
terminal.println("At least ONE day MUST be selected");
// terminal.println(String("Time zone offset: ") + t.getTZ_Offset()); //
// Get timezone offset (in seconds)
terminal.flush();
for (int i = 1; i <= 7;
i++) { // Process weekdays (1. Mon, 2. Tue, 3. Wed, ...)
if (t.isWeekdaySelected(i)) {
terminal.println(String("Day ") + i + " is selected");
terminal.flush();
nowseconds = ((hour() * 3600) + (minute() * 60) + second());
startsecondswd = (t.getStartHour() * 3600) + (t.getStartMinute() * 60);
// Serial.println(startsecondswd); // used for debugging
if (nowseconds >= startsecondswd) {
terminal.print("Auto Mode STARTED at");
terminal.println(String(" ") + t.getStartHour() + ":" +
terminal.flush();
if (nowseconds <=
startsecondswd +
90) { // 90s on 60s timer ensures 1 trigger command is sent
// code here to switch the relay ON
terminal.println("Auto Mode Device NOT STARTED today");
terminal.flush();
stopsecondswd = (t.getStopHour() * 3600) + (t.getStopMinute() * 60);
// Serial.println(stopsecondswd); // used for debugging
if (nowseconds >= stopsecondswd) {
terminal.print("Auto Mode STOPPED at");
terminal.println(String(" ") + t.getStopHour() + ":" +
t.getStopMinute());
terminal.flush();
if (nowseconds <=
stopsecondswd +
// code here to switch the relay OFF
terminal.println("Auto Mode is ON");
terminal.flush();
terminal.println("Auto Mode INACTIVE today");
terminal.flush();
// nothing to do today, check again in 30 SECONDS time
terminal.println();
void reconnectBlynk() {
if (!Blynk.connected()) {
if (Blynk.connect()) {
BLYNK_LOG("Reconnected");
BLYNK_LOG("Not reconnected");
if (Blynk.connected()) {
/*void tempSwitchOn() {
void tempSwitchOff() {
terminal.println("OFF");
At the end of the code is some functions, tempSwichOn & Off, that I tried to call from the BLYNK_WRITE(V2) button but it did not work I even tried to call it from the Timer function.
Hope someone can help.
Thank you.
