there seems to be an error with table widget on IOS.
I run the below code extract - it works as expected on Android Blynk App but NOT on IOS Blynk App.
Eugene can you pls confirm if there indeed is an error ?
I’ve just tested table widget and it works fine for me.
Sending addRow with id of the existing row is currently not supported on server and actually will result as a corrupted table with few rows with the same id. Although it looks ok on Android at the time of the command, you’ll see the “true” state of the widget after syncing from server. iOS ignores such input.
Next iOS update will be about creating/previewing standalone apps within Blynk app and expected somewhere next week.
ok - and just one final question.
Is this planned to be fixed ? @Dmitriy (and documented so other don’t spends hours wondering why it doesn’t work as expected ?)
