Hay guys
I wanna ask, if i made a project with one device and connected to app Blynk, may question is, Can some people monitor project i made with blynk ? Or multiuser
Yes, it’s called App Sharing and costs 1000 units of energy to turn it on for a project.
Multiple shared users can operate the app as normal, but they can’t put the app into edit mode and make changes to the layout.
I have 700 energy, so if i want to share it, so i must add the energy from Blynk about 1000, like that ? And the menu in Widget box will add ?
You’ll need top add energy, or remove any unused widgets to recycle energy.
Sharing is done by stopping the app, hitting the ‘Nut’ icon and turning Shared Access On.
Unlike widgets, this energy is non-refundable, so if you turned shared access off you don’t get the energy back (but I believe that you can turn it back on without being charged again).
If you modify the app then all of your users see the modified version of the app, without having to pay again.
Note that if you put the app into Stop (edit) mode then none of the shared access users will be able to access the app while its stopped.
Thank you very much Sir, i will try it, if i get the problem or still not understand i will discus again in this group, good evening from Indonesia
