I haven’t slept for several nights
I am using Arduino Uno R3 with ESP8266 software serial connection. Then I have VL53L0X distance sensor and DS18B20 temperature sensor.
My project code with DS182b20 sensor works fine, my code with VL53L0X works fine, but when I put these functions together, Blyk is connected, but stops after Ping and doesn’t continue timer functions. In Blynk app I can see that device connected, but no values updated.
Do you have any idea, why VL53L0X and DS18B20 doesn’t work together with Blynk?
This code with distance sensor and Blynk works:
//Blynk darbiibai
#include <ESP8266_Lib.h>
char auth[] = "aasdasd";
char ssid[] = "asdasdasd";
char pass[] = "asdasdad";
SoftwareSerial EspSerial(3, 4); // RX, TX
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
//Blynk darbiibu izpildei
//attalumam
#include <Wire.h>
#include <VL53L0X.h>
VL53L0X sensor;
int noinformets=0;
#define LONG_RANGE
//Temperatūrai
//attaalumam
Wire.begin();
sensor.init();
sensor.setTimeout(500);
#if defined LONG_RANGE
// lower the return signal rate limit (default is 0.25 MCPS)
sensor.setSignalRateLimit(0.1);
// increase laser pulse periods (defaults are 14 and 10 PCLKs)
sensor.setVcselPulsePeriod(VL53L0X::VcselPeriodPreRange, 18);
sensor.setVcselPulsePeriod(VL53L0X::VcselPeriodFinalRange, 14);
#endif
// Set ESP8266 baud rate
timer.setInterval(2000L, attalums);
timer.setInterval(3000L, temperatura); // ik 5 sec
// timer.setInterval(30000L, aratemper); // ik 5 minūtes
void myTimerEvent()
Blynk.virtualWrite(V0, millis() / 1000);
void attalums()
int distance=0;
int granululimenis=0;
int counter=1;
const int tukss = 100;
distance=sensor.readRangeSingleMillimeters()/10;
if (distance>0 && distance<tukss+10){
granululimenis=tukss-distance;
Serial.print("Granulu līmenis: ");
Serial.println(granululimenis);
Blynk.virtualWrite(V5, granululimenis);
void temperatura(){
float katlatemp;
katlatemp=88;
Serial.print("Katla temperatūra: ");
Serial.println(katlatemp);
Blynk.virtualWrite(V2, katlatemp);
This code with Temperature sensor and Blynk works:
//Blynk darbiibai
char auth[] = "sdasdad";
char ssid[] = "asdsad";
char pass[] = "sdsadad";
//Temperatūrai
#include <OneWire.h>
//Katla temp.
#define ONE_WIRE_BUS 6 //uz kura digitālā pin temp. lasītājs
//Temperatūrai
sensors.begin();
void myTimerEvent()
void attalums()
int distance=0;
int counter=1;
distance=55; //sensor.readRangeSingleMillimeters()/10;
void temperatura(){
float katlatemp;
katlatemp=sensors.getTempCByIndex(0);
Together doesnt work. Blynk connected, but timer functions not running
//attalumam
#include <Wire.h>
VL53L0X sensor;
int noinformets=0;
#define LONG_RANGE
//Blynk darbiibai
char auth[] = "sdcsdf";
char ssid[] = "scsdcsd";
char pass[] = "sdsdf";
//Temperatūrai
//Katla temp.
//attaalumam
Wire.begin();
sensor.init();
#endif
//Temperatūrai
sensors.begin();
void myTimerEvent()
void attalums()
int distance=0;
int counter=1;
void temperatura(){
float katlatemp;
