Hey Blynkers,
I’m a noob wanting to use a Wemos D1 mini + arduino IDE to open my garage door. The issue I’ve got is getting a relay to act like a momentary push switch. In the Blynk app, its fine. Just set the button to ‘push’. The problem is, I also want to be able to open/close the door using IFTTT webhooks. This works, however it latches the pin high = relay latches closed. I was hoping to use some code to get something like webhook pulls virtual pin high - code in Wemos detects pin is high - runs a loop pulling the digital pin high for a second then low again.
I’ve looked for an answer in these forums, but still haven’t been able to pull it off. I’m not a coder at all, the following was copy/pasted from other projects here, but doesn’t work. I’m sure this is a fairly simple task, can anyone help?
SimpleTimer tripWire;
char auth[] = "***";
char ssid[] = "";
char pass[] = "";
int outputPin = D5;
int inputPin = V1;
int val = 0;
//pasted code starts here
BLYNK_WRITE(inputPin) {
int pinValue = param.asInt();
if (pinValue==HIGH) { // virtual pin V1 goes HIGH when pressed in the app, goes LOW when released.
tripActivate();
void tripActivate() {
digitalWrite(outputPin, HIGH);
tripWire.setTimeout(1000L, tripDeactivate);
void tripDeactivate() {
digitalWrite(outputPin, LOW);
//pasted code ends here
But you know the format looks different but tis the same code basically.
