Hello good day ! , I used blynk more than 2 years ago, I already believe, I put it together and installed it and set it up for my house and I never touch it again now I am going to add many more things to put together but when compiling my old code it throws this error that I cannot know why.
The truth I have lost libraries and many more things from the arduino since in 2 years I reinstalled the pc several times.
I use Arduno Mega + Ethernet Shield W5100.
Compile with arduino 1.8.13
Error: āV73ā was not declared in this scope
Line: : WidgetTerminal terminal(V73);
#include <Blynk.h>
#include <Ethernet.h>
#include <DHT.h>
#include <Wire.h>
#include <TimeLib.h>
#include <WidgetRTC.h>
#define DHTPIN 23
#define DHTTYPE DHT11
char auth[] = "";
#define W5100_CS 10
#define SDCARD_CS 4
WidgetLED ledbomba(V72);
DHT dht(DHTPIN, DHTTYPE);
WidgetRTC rtc;
bool Connected2Blynk = false;
const int BombaAgua = 22;
const int ReflectorPatio = 24;
const int Presurizadora = 26;
const int NivelTanke = 28;
const int SensorPorton = 52;
const int BotonCuarto = 50;
const int ReflectorPorton = 53;
const int ReflectorTerreno = 51;
const int AperturaPorton = 49;
const int LuzCuarto = 47;
int EstadoBombaAgua = LOW;
int EstadoReflectorPatio = LOW;
int EstadoPresurizadora = LOW;
int EstadoNivelTanke = LOW;
bool isFirstConnect = false;
int EstadoLuzCuarto, EstadoBotonCuarto, EstadoReflectorPorton, EstadoReflectorTerreno, EstadoAperturaPorton, EstadoSensorPorton;
int HoraDia = 5;
int HoraNoche = 20;
pinMode(SDCARD_CS, OUTPUT);
digitalWrite(SDCARD_CS, HIGH);
Blynk.begin(auth, IPAddress(192, 168, 1, 14), 8080);
pinMode(BombaAgua, OUTPUT);
pinMode(ReflectorPatio, OUTPUT);
pinMode(Presurizadora, OUTPUT);
pinMode(LuzCuarto, OUTPUT);
pinMode(ReflectorPorton, OUTPUT);
pinMode(ReflectorTerreno, OUTPUT);
pinMode(AperturaPorton, OUTPUT);
pinMode(BotonCuarto, INPUT_PULLUP);
pinMode(SensorPorton, INPUT_PULLUP);
pinMode(NivelTanke, INPUT_PULLUP);
//dht.begin();
//rtc.begin();
// setSyncInterval(10 * 60);
//terminal.clear();
//terminal.println(F("Jarvis Home Iniciado V2"));
//terminal.println(F("-------------"));
//terminal.println(F("Version: " BLYNK_VERSION));
//terminal.flush();
timer.setInterval(11000L, CheckConnection);
timer.setInterval(1400L, botonluzcuarto);
//timer.setInterval(15000L, temperaturayhumedad);
//timer.setInterval(13200L, sensorporton);
void CheckConnection(){
Connected2Blynk = Blynk.connected();
if(!Connected2Blynk){
Serial.println("Not connected to Blynk server");
else{
Serial.println("Still connected to Blynk server");
if (Connected2Blynk) {
BLYNK_CONNECTED() {
if (isFirstConnect) {
Blynk.syncAll();
Blynk.syncVirtual(V1);
Blynk.syncVirtual(V2);
Blynk.syncVirtual(V3);
BLYNK_WRITE(V1) {
EstadoBombaAgua = param.asInt();
digitalWrite(BombaAgua, EstadoBombaAgua);
if (EstadoBombaAgua == 0) {
ledbomba.on();
terminal.println(F("Bomba Encendida"));
terminal.flush();
else {
ledbomba.off();
terminal.println(F("Bomba Apagada"));
terminal.flush();
BLYNK_WRITE(V2) {
EstadoReflectorPatio = param.asInt();
digitalWrite(ReflectorPatio, EstadoReflectorPatio);
terminal.println(F("Reflector Patio: "));
terminal.println(EstadoReflectorPatio);
terminal.flush();
BLYNK_WRITE(V3) {
EstadoPresurizadora = param.asInt();
digitalWrite(Presurizadora, EstadoPresurizadora);
if (EstadoPresurizadora == 0) {
Blynk.virtualWrite(V103, "Presurizada");
else {
Blynk.virtualWrite(V103, "Normal");
BLYNK_WRITE(V4) {
EstadoLuzCuarto = param.asInt();
digitalWrite(LuzCuarto, EstadoLuzCuarto);
BLYNK_WRITE(V5) {
EstadoReflectorPorton = param.asInt();
digitalWrite(ReflectorPorton, EstadoReflectorPorton);
BLYNK_WRITE(V6) {
EstadoReflectorTerreno = param.asInt();
digitalWrite(ReflectorTerreno, EstadoReflectorTerreno);
BLYNK_WRITE(V7) {
EstadoAperturaPorton = param.asInt();
digitalWrite(AperturaPorton, EstadoAperturaPorton);
BLYNK_WRITE(V8)
HoraNoche = param.asInt();
terminal.println("Hora Noche Modificada: ");
terminal.println(HoraNoche);
terminal.flush();
BLYNK_WRITE(V9)
HoraDia = param.asInt();
terminal.println("Hora Dia Modificada: ");
terminal.println(HoraDia);
terminal.flush();
void sensorporton()
EstadoSensorPorton = digitalRead(SensorPorton);
int hora = hour();
if (hora >= HoraDia && hora <= HoraNoche) {
terminal.println("Sensonr Porton Activo");
terminal.flush();
if (EstadoSensorPorton != 0) {
Blynk.virtualWrite(V5, "1");
Blynk.virtualWrite(V5, "0");
void botonluzcuarto()
if (digitalRead(BotonCuarto) == LOW) {
if (EstadoBotonCuarto != LOW) {
EstadoLuzCuarto = !EstadoLuzCuarto;
Blynk.virtualWrite(V4, EstadoLuzCuarto);
EstadoBotonCuarto = LOW;
EstadoBotonCuarto = HIGH;
void temperaturayhumedad()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
String currentDate = String(day()) + "/" + month() + "/" + year();
terminal.println("Error Temperatura Cuarto Kevin: ");
terminal.print(currentTime);
terminal.print(" ");
terminal.print(currentDate);
terminal.println();
terminal.flush();
return;
Blynk.virtualWrite(V10, h);
Blynk.virtualWrite(V11, t);
void sensortanque()
EstadoNivelTanke = digitalRead(NivelTanke);
if (EstadoBombaAgua != 0) {
Blynk.virtualWrite(V1, 1);
} else
Blynk.virtualWrite(V1, 0);
