Hi.
i am using Arduino Uno and 2 ultrasonic sensor and i use virtual pins to read data sensor. I have problems with virtual pins. I use 2 widget gauges. gauge1 for virtual pin 4 and gauge2 for virtual pin 8. Unfortunately only virtual 4 is reading data. Here is my source code.
#define TRIGGER 9
#define ECHO 10
#define TRIGGER1 7
#define ECHO1 6
#include <Ethernet.h>
SoftwareSerial DebugSerial(10, 11); // RX, TX
char auth[] = "my auth token";
void notifyUptime()
long uptime = millis() / 60000L;
Blynk.notify(String("Running for ") + uptime + " minutes.");
BLYNK_WRITE(V1)
int pinValue1 = param.asInt(); // assigning incoming value from pin V1 to a variable
BLYNK_WRITE(V2)
int pinValue2 = param.asInt(); // assigning incoming value from pin V2 to a variable
BLYNK_WRITE(V3)
int pinValue3 = param.asInt(); // assigning incoming value from pin V3 to a variable
BLYNK_WRITE(V4)
int pinValue4 = param.asInt(); // assigning incoming value from pin V4 to a variable
BLYNK_WRITE(V5)
int pinValue5 = param.asInt(); // assigning incoming value from pin V5 to a variable
BLYNK_WRITE(V6)
int pinValue6 = param.asInt(); // assigning incoming value from pin V6 to a variable
BLYNK_WRITE(V7)
int pinValue7 = param.asInt(); // assigning incoming value from pin V7 to a variable
BLYNK_WRITE(V8)
int pinValue8 = param.asInt(); // assigning incoming value from pin V8 to a variable
DebugSerial.begin(9600);
Blynk.begin(Serial, auth);
pinMode(TRIGGER, OUTPUT);
pinMode(ECHO, INPUT);
pinMode(TRIGGER1, OUTPUT);
pinMode(ECHO1, INPUT);
//Notify immediately on startup
Blynk.notify("Device started");
// Setup a function to be called every minute
timer.setInterval(60000L, notifyUptime);
long duration, distance, duration1, distance1;
digitalWrite(TRIGGER, LOW);
delayMicroseconds(2);
digitalWrite(TRIGGER1, LOW);
digitalWrite(TRIGGER, HIGH);
delayMicroseconds(10);
digitalWrite(TRIGGER1, HIGH);
duration = pulseIn(ECHO, HIGH);
duration1 = pulseIn(ECHO1, HIGH);
distance = (duration/2) / 29.1;
Blynk.virtualWrite(V4, distance);
distance1 = (duration1 /2) / 29.1;
Blynk.virtualWrite(V8, distance1);
//--------------first sensor-------------
if(distance <= 1000)
Blynk.virtualWrite(V1, 255);
Blynk.virtualWrite(V1, 0);
if(distance <= 800)
Blynk.virtualWrite(V2, 255);
Blynk.virtualWrite(V2, 0);
if(distance <= 100)
Blynk.virtualWrite(V3, 255);
Blynk.virtualWrite(V3, 0);
if(distance <= 80)
Blynk.notify("Overflow! Please clean up the trash can");
//---------------second sensor-------------------
if(distance1 <= 1000)
Blynk.virtualWrite(V5, 255);
Blynk.virtualWrite(V5, 0);
if(distance1 <= 800)
Blynk.virtualWrite(V6, 255);
Blynk.virtualWrite(V6, 0);
if(distance1 <= 100)
Blynk.virtualWrite(V7, 255);
Blynk.virtualWrite(V7, 0);
if(distance1 <= 4)
Blynk.email("my e-mail @gmail.com", "Subject: IoT Trash Can", "Overflow! Please clean up the trash can.");
delay(200);
i really need help.
