Wondered if somebody could have a look at my code and tell me where i’m going wrong… I’m trying to get a virtual LED to light when I flick a switch in Blynk, but it just wont Light the virtual LED. I’m only an amatuer programmer so my code is probably a little long winded, for that I apologies! Any help you can give will be much appreciated!! I’ve tried a few different ways looking through passed threads but none of them have worked… Please Help!
#include <arduino.h>
#include "DHT.h"
//Globals for DHT sensor
#define DHTPIN 3
#define DHTTYPE DHT22
DHT dht (DHTPIN, DHTTYPE);
char auth[] = "token here";
char ssid[] = "ssid";
char pass[] = "password";
//Select your pin with physical button
const int btnPin = 1;
WidgetLED led3(V3);
//V3 LED Widget represents the physical button state
boolean btnState = false;
void buttonLedWidget()
// Read button
boolean isPressed = (digitalRead(btnPin) == LOW);
//If State has changed...
if (isPressed != btnState) {
if (isPressed) {
led3.on();
led3.off();
btnState = isPressed;
void sendUptime()
Blynk.virtualWrite(4, millis()/1000);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
timer.setInterval(1000, sendUptime);
// Setup physical button pin (active low)
pinMode(btnPin, INPUT_PULLUP);
timer.setInterval(500L, buttonLedWidget);
dht.begin();
