Virtual button to control relay on GPIO 16
Yeah I tried it;and it seems to work fine :slight_smile:
It wasnt in my code but it was in the newer version of the blynk edgent example
Oh look, you were using a very early version of the Edgent example!
I also want to add a door sensor to pin 14 and display the if the door is open or not on a widget lcd
is this correct
#define BLYNK_TEMPLATE_ID ""
#define BLYNK_TEMPLATE_NAME ""
#define BLYNK_FIRMWARE_VERSION        "1.0"
//#define BLYNK_DEBUG
#define APP_DEBUG
const int wifists=2;
const int doorpin = 14;
int slider;
#include "BlynkEdgent.h"
#define USE_NODE_MCU_BOARD
WidgetLCD lcd(V3);
BLYNK_WRITE(V7)
 slider = param.asInt();
BLYNK_WRITE(V0)
  int pin = param.asInt();
  if (param.asInt()){
  digitalWrite(16, LOW);
  timer.setTimeout(slider, [] () {digitalWrite(16, HIGH);Blynk.virtualWrite(V0,LOW);} );
  BLYNK_WRITE(V1)
  if (param.asInt()){
  digitalWrite(4, LOW);
  timer.setTimeout(slider, [] () {digitalWrite(4, HIGH);Blynk.virtualWrite(V1,LOW);} );
BLYNK_WRITE(V2)
  if (param.asInt()){
  digitalWrite(5, LOW);
  timer.setTimeout(slider, [] () {digitalWrite(5, HIGH);Blynk.virtualWrite(V2,LOW);} );
  delay(100);
  pinMode(16, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(wifists, OUTPUT);
  digitalWrite(16,HIGH);
  digitalWrite(4,HIGH);
  digitalWrite(5,HIGH);
  BlynkEdgent.begin();
  timer.setInterval(1000L, connect);
  timer.setInterval(100L, doorstate);
void connect()
 if (Blynk.connected()) {
    digitalWrite(wifists, HIGH);//turn on wifi status led if device isconnected to internet
    digitalWrite(wifists, LOW);
void doorstate(){
if (digitalRead(doorpin) == HIGH) {
    lcd.print(0, 0, "Door Closed");
  }else{
    lcd.print(0, 0, "Door Open");
BLYNK_CONNECTED(){
    Blynk.syncVirtual(V7);
  BlynkEdgent.run();
