i created a car with 4 DC-motors. It is controlled with Blynk and a Raspberry Pi with direct access to the GPIO.
Now I want to add a camera with a video stream. So I set up motion and started the streaming server. It is reachable under the IP-Adress under port 8081.
In my web-browser the stream works very well, but in the widget is only a grey frame shown.
The stream is coded in mp4 and has a resolution of 480x360 pixel with 10 fps.
How can I fix the problem?
Do I have to configure anything else, or should I change the codec?
