VC0706 Camera + Blynk to Take picture
hello, I have a question about Blynk and the camera.
I’ve made a project, took pictures using esp32 cam, the picture will appear on blynk.
with this tutorial, but I have a little change, where I add the button widget on blynk. which is useful for triggering taking pictures
this is the program
#include "esp_camera.h"
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
// WARNING !!! Make sure that you have either selected ESP32 Wrover Module,
// or another board which has PSRAM enabled
// Select camera model
// # define CAMERA_MODEL_WROVER_KIT
// #define CAMERA_MODEL_ESP_EYE
// #define CAMERA_MODEL_M5STACK_PSRAM
// #define CAMERA_MODEL_M5STACK_WIDE
#define CAMERA_MODEL_AI_THINKER
#include "camera_pins.h"
// #define LED 21
// #define BUTTON 15
const char * ssid = "xxx";
const char * password = "xxx";
char auth [] = "xxxxx";
String my_Local_IP;
void startCameraServer ();
BLYNK_WRITE (V2)
  if (param.asInt ())
    capture ();
void capture ()
  uint32_t number = random (40000000);
  Blynk.notify ("Someone is at the door ..");
  Serial.println ("http: //" + my_Local_IP + "/ capture? _Cb =" + (String) number);
  Blynk.setProperty (V1, "urls", "http: //" + my_Local_IP + "/ capture? _Cb =" + (String) number);
  delay (1000);
void setup () {
  Serial.begin (115200);
  Serial.setDebugOutput (true);
  Serial.println ();
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  // init with high specs to pre-allocate larger buffers
  if (psramFound ()) {
    config.frame_size = FRAMESIZE_UXGA;
    config.jpeg_quality = 10;
    config.fb_count = 2;
    config.frame_size = FRAMESIZE_SVGA;
    config.jpeg_quality = 12;
    config.fb_count = 1;
#if defined (CAMERA_MODEL_ESP_EYE)
  pinMode (13, INPUT_PULLUP);
  pinMode (14, INPUT_PULLUP);
#endif
  // camera init
  esp_err_t err = esp_camera_init (& config);
  if (err! = ESP_OK) {
    Serial.printf ("Camera init failed with error 0x% x", err);
    return;
  sensor_t * s = esp_camera_sensor_get ();
  // initial sensors are flipped vertically and colors are a bit saturated
  if (s-> id.PID == OV3660_PID) {
    s-> set_vflip (s, 1); // flip it back
    s-> set_brightness (s, 1); // up the blightness just a bit
    s-> set_saturation (s, -2); // lower the saturation
  // drop down frame size for higher initial frame rates
  s-> set_framesize (s, FRAMESIZE_QVGA);
#if defined (CAMERA_MODEL_M5STACK_WIDE)
  s-> set_hmirror (s, 1);
#endif
  WiFi.begin (ssid, password);
  while (WiFi.status ()! = WL_CONNECTED) {
    delay (500);
    Serial.print (".");
  Serial.println ("");
  Serial.println ("WiFi connected");
  Serial.print ("Camera Ready! Use 'http: //");
  Serial.print (WiFi.localIP ());
  my_Local_IP = WiFi.localIP (). toString ();
  Serial.println ("'to connect");
  Blynk.begin (auth, ssid, password);
void loop () {
  Blynk.run ();
BUT, the picture is not satisfactory.
I want to replace the board or camera. I want to use a TTC vc0706 camera and a nodemcu.
Can it be applied using blynk?
Thank You
