I’m using the Timer widget to trigger a relay once every morning (Start at: 8:00:00 Stop at: 8:00:00 – no seconds used -).
The following code is working and the relay is triggering once, the volt meter is also showing a single pulse. However, the monitor is showing double pulse unless I’m reading it wrong. Shouldn’t the text be printed only once?
TIA
Text as shown in the monitor:
=== Relay on === Start run time: 744528
=== Relay on === Start run time: 744531
End run time: 745428
End run time: 745431
// --- ESP8266-12E dev kit ---
// #define D0 16
// #define D1 5 // I2C Bus SCL (clock)
#define D2 4 // I2C Bus SDA (data)
// #define D3 0
// #define D4 2 // onboard LED, but inverted logic
// #define D5 14 // SPI Bus SCK (clock)
// #define D6 12 // SPI Bus MISO
// #define D7 13 // SPI Bus MOSI
// #define D8 15 // SPI Bus SS (CS)
// #define D9 3 // RX0 (Serial console)
// #define D10 1 // TX0 (Serial console)
char auth[] = "xxx";
char ssid[] = "xxx";
char pass[] = "xxx";
BLYNK_WRITE(V5)
// Gets a trigger at startTime.
// This method will be triggered every day
// until the widget is removed or project stopped or
// cleaned stop/start fields of widget itself
digitalWrite(D2, HIGH); // turns on relay
Serial.print("=== Relay on === ");
Serial.print("Start run time: "); // tells me when it turns on
Serial.println(millis());
timer.setTimeout(900, TurnOffRelay);
void TurnOffRelay()
digitalWrite(D2, LOW);
Serial.print("End run time: "); // tells me when it turns off
pinMode(D2, OUTPUT); // relay pin #
digitalWrite(D2, LOW); // make sure is not turned on at power-up
// Wait until connected
