which use for example using the sensor dht11.
and what libraries have to download.
thank you.
thank you.
I’ve been using the DHT library. I think it contains a few examples. Here’s how I’ve been using it for my home-brewed Nest-style IoT thermostat:
Thank you very much for your help, I managed to bring up the humidity and temperature values on the display value of blynk.
Now how do I put Âşc% and in front of the values?
I made this code.
define BLYNK_PRINT Serial // Comment this out to disable prints and save space
include <SPI.h>
include <Ethernet.h>
include <BlynkSimpleEthernet.h>
include <dht.h>
define dht_dpin A0 //Pino DATA do Sensor ligado na porta Analogica A1
dht DHT; //Inicializa o sensor
char auth[] = “xxxxxxxxxxxxxxxxxxxxxxxxxxx”;
Blynk.begin(auth);
// You can also specify server.
// For more options, see BoardsAndShields/Arduino_Ethernet_Manual example
//Blynk.begin(auth, “your_server.com”, 8442);
//Blynk.begin(auth, IPAddress(192,168,1,100), 8888);
DHT.read11(dht_dpin); //Lê as informações do sensor
Blynk.virtualWrite(1, DHT.temperature);
Blynk.virtualWrite(2, DHT.humidity);
I’m not using the degree symbol or C/F on my dashboard, but there are instructions for doing so at the bottom of this page:
Sorted out. Thanks a lot for the help.
A0? DHT11 uses digital output,
do it like
#include <DHT.h>
#define DHTPIN 14
DHT dht(DHTPIN, DHTTYPE);
char auth[] =
Blynk.begin(auth,
dht.begin();
void readtemp()
float h = dht.readHumidity();//outside
Blynk.virtualWrite(V1, h);
float t = dht.readTemperature();//outside
Blynk.virtualWrite(V2, t);
You can use this to display:
int tempHumid = (int)h;
int tempTemp = (int)c;
String humid = (String)tempHumid;
String temp = (String)tempTemp;
humid += "%";
temp += "°C";
Change variable names, but this is how I do it
