Using "Blynk MQTT client for ESP-IDF and Cellular", but no connection to Blynk.Console Devices, yet
Subscription: Free
HW: ESP32 with SIM7600 (LILYGO)
Device created in Blynk.Console with no dashboard, yet. I am expecting to get the device online first, then to create the dashboard to load the data.
Using ESP-IDF-Cellular code, the following defines are set according to the parameters provided in Blynk Console within my Devices - ESP32GsmAnalysisDevice
(these defines were altered with dots to avoid showing private parameters in this post):
#define CONFIG_BLYNK_TEMPLATE_ID “TMP…L1”
#define CONFIG_BLYNK_TEMPLATE_NAME “ESP…sis”
In the mqtt_gsm_main.c file:
static void mqtt_event_handler(void *handler_args, esp_event_base_t base, int32_t event_id, void *event_data)
case MQTT_EVENT_CONNECTED:
cJSON_AddItemToObject(root, “tmpl”, cJSON_CreateString(CONFIG_BLYNK_TEMPLATE_ID));
static void register_auth_key_cmd(void)
auth_cmd_args.token = arg_str0(NULL, NULL, “2q …TOKEN…zzs”, “blynk auth token”);
void app_main()
At the end, app_main function gets fully executed, but there is no connection with Blynk.Console.
So, the device never gets online.
Of course, the case MQTT_EVENT_CONNECTED is never executed, so no MQTT logs(per README.md):
I (38510) [MQTTS]: MQTT_EVENT_CONNECTED
I (38730) [MQTTS]: MQTT_EVENT_SUBSCRIBED, msg_id=5258
I (39460) [MQTTS]: MQTT_EVENT_PUBLISHED, msg_id=23955
In the Blynk websites, there was mentioned to try:
ping blynk.cloud
Pinging blynk.cloud [64.225.16.22] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 64.225.16.22:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
I am digging into the connection sequence, and debugging the code, but I would really appreciate your insight, since it is very useful.
Please, let me know if more information is required from me.
Thanks for your attention.
When you post code to this forum it needs to have triple backticks at the beginning and end so that it displays correctly.
You can copy/paste these example characters if you can’t find the correct symbol on your keyboard.
When you do post code, I’d suggest posting the entire file, not just snippets, and redacting sensitive information by replacing it with the word “REDACTED”.
Sharing your serial monitor/terminal output would probably be useful, once again use triple backticks at the beginning and end.
What modem config have you used for your particular board?
Have you followed the instructions to configure the device auth token after doing the build and run process?
Have
Pete, an apology for that.
Below come the answers to your questions:
#define CONFIG_BLYNK_TEMPLATE_ID “REDACTED”
#define CONFIG_BLYNK_TEMPLATE_NAME “REDACTED”
1.This is the entire file: mqtt_gsm_main.c
 * SPDX-FileCopyrightText: 2024 Andrii Yarmolenko for Blynk Technologies Inc.
 * SPDX-License-Identifier: Apache-2.0
#include <stdio.h>
#include <stdint.h>
#include <stdlib.h>
#include <inttypes.h>
#include <string.h>
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "freertos/event_groups.h"
#include "esp_system.h"
#include "esp_event.h"
#include "esp_log.h"
#include "esp_netif.h"
#include "nvs.h"
#include "nvs_flash.h"
#include "esp_console.h"
#include "argtable3/argtable3.h"
#include "esp_ota_ops.h"
#include "esp_http_client.h"
#include "esp_https_ota.h"
#include "driver/uart.h"
#include "driver/gpio.h"
#include "netif/ppp/pppos.h"
#include "netif/ppp/ppp.h"
#include "lwip/err.h"
#include "netif/ppp/pppapi.h"
#include <esp_wifi.h>
#include <cJSON.h>
#include "mqtt_client.h"
#if !defined(CONFIG_BLYNK_FIRMWARE_TYPE) && defined(CONFIG_BLYNK_TEMPLATE_ID)
    #define CONFIG_BLYNK_FIRMWARE_TYPE         CONFIG_BLYNK_TEMPLATE_ID
#endif
#if !defined(CONFIG_BLYNK_FIRMWARE_VERSION)
    #define CONFIG_BLYNK_FIRMWARE_VERSION      "0.0.0"
#endif
#if !defined(CONFIG_BLYNK_TEMPLATE_ID) || !defined(CONFIG_BLYNK_TEMPLATE_NAME)
    #error "Please specify your BLYNK_TEMPLATE_ID and BLYNK_TEMPLATE_NAME"
#endif
#define BLYNK_PARAM_KV(k, v)    k "\0" v "\0"
#if CONFIG_BLYNK_MQTTS_MODE
    #include "root_certificates.h"
    static const char *MQTTTAG = "[MQTTS]";
#else
    static const char *MQTTTAG = "[MQTT]";
#endif
static TickType_t mqtt_offline_timestamp = 0;
static TaskHandle_t modem_task = NULL;
static ppp_pcb *ppp = NULL;
static struct netif ppp_netif;
static void gsm_init(void);
static int get_nvs_blynk_auth_token(char *token, size_t *len)
    nvs_handle_t my_handle;
    if (nvs_open("storage", NVS_READONLY, &my_handle) != ESP_OK)
        ESP_LOGE("NVS", "can't open storage");
        return -1;
    const int rc = nvs_get_str(my_handle, "blynk_token", token, len);
    nvs_close(my_handle);
    return rc;
static int set_nvs_blynk_auth_token(const char *token)
    if (nvs_open("storage", NVS_READWRITE, &my_handle) != ESP_OK)
        return -1;
    const int rc = (ESP_OK != nvs_set_str(my_handle, "blynk_token", token) || ESP_OK != nvs_commit(my_handle));
    return rc;
static int starts_with(const char *str, const char *prefix)
    size_t len_prefix = strlen(prefix);
    size_t len_str = strlen(str);
    if (len_str < len_prefix) {
        return 0;
    return strncmp(str, prefix, len_prefix) == 0;
static u32_t p_output_callback(ppp_pcb *pcb, u8_t *data, u32_t len, void *ctx)
    const uint32_t ret = uart_write_bytes(CONFIG_GSM_UART_NUM, (const char*)data, len);
    //uart_wait_tx_done(CONFIG_GSM_UART_NUM, 10 / portTICK_PERIOD_MS);
    return ret;
static int send_cmd(const uart_port_t uart_num, const char *cmd, const char *rsp1, const char *rsp2, const int timeout_ms)
    uart_flush(CONFIG_GSM_UART_NUM);
    uart_write_bytes(CONFIG_GSM_UART_NUM, cmd, strlen(cmd));
#if CONFIG_GSM_AT_CMD_DEBUG
    ESP_LOGI("[GSM]", "snd[%s]", cmd);
#endif
    uint8_t d[256];
    int len = 0;
    for (int i = 0; i < timeout_ms; i += 20)
        const int len_tmp = uart_read_bytes(CONFIG_GSM_UART_NUM, d + len, sizeof(d) - len - 1, 20 / portTICK_PERIOD_MS);
        if (len_tmp)
            len += len_tmp;
            d[len] = '\0';
            ESP_LOGI("[GSM]", "rcv[%s]", d);
#endif
            if (rsp1 && strstr((const char *)d, rsp1))
                return 1;
            if (rsp2 && strstr((const char *)d, rsp2))
                return 2;
    return -1;
static void p_status_cb(ppp_pcb *pcb, int err_code, void *ctx)
    LWIP_UNUSED_ARG(ctx);
    struct netif *pppif = ppp_netif(pcb);
    switch (err_code) {
        case PPPERR_NONE:
            ESP_LOGI("[GSM]","status_cb: Connected");
            #if PPP_IPV4_SUPPORT
            ESP_LOGI("[GSM]","   ipaddr    = %s", ipaddr_ntoa(&pppif->ip_addr));
            ESP_LOGI("[GSM]","   gateway   = %s", ipaddr_ntoa(&pppif->gw));
            ESP_LOGI("[GSM]","   netmask   = %s", ipaddr_ntoa(&pppif->netmask));
            #endif
            #if PPP_IPV6_SUPPORT
            ESP_LOGI("[GSM]","   ip6addr   = %s", ip6addr_ntoa(netif_ip6_addr(pppif, 0)));
            #endif
            break;
        case PPPERR_PARAM:
            ESP_LOGE("[GSM]","status_cb: Invalid parameter");
            break;
        case PPPERR_OPEN:
            ESP_LOGE("[GSM]","status_cb: Unable to open PPP session");
            break;
        case PPPERR_DEVICE:
            ESP_LOGE("[GSM]","status_cb: Invalid I/O device for PPP");
            break;
        case PPPERR_ALLOC:
            ESP_LOGE("[GSM]","status_cb: Unable to allocate resources");
            break;
        case PPPERR_USER:
            /* ppp_free(); -- can be called here */
            ESP_LOGW("[GSM]","status_cb: User interrupt (disconnected)");
            break;
        case PPPERR_CONNECT:
            ESP_LOGE("[GSM]","status_cb: Connection lost");
            break;
        case PPPERR_AUTHFAIL:
            ESP_LOGE("[GSM]","status_cb: Failed authentication challenge");
            break;
        case PPPERR_PROTOCOL:
            ESP_LOGE("[GSM]","status_cb: Failed to meet protocol");
            break;
        case PPPERR_PEERDEAD:
            ESP_LOGE("[GSM]","status_cb: Connection timeout");
            break;
        case PPPERR_IDLETIMEOUT:
            ESP_LOGE("[GSM]","status_cb: Idle Timeout");
            break;
        case PPPERR_CONNECTTIME:
            ESP_LOGE("[GSM]","status_cb: Max connect time reached");
            break;
        case PPPERR_LOOPBACK:
            ESP_LOGE("[GSM]","status_cb: Loopback detected");
            break;
        default:
            ESP_LOGE("[GSM]","status_cb: Unknown error code %d", err_code);
            break;
    if (err_code != PPPERR_USER && err_code != PPPERR_NONE && ppp)
       //gsm_init();
static void gsm_task(void *pvParameters)
    if (uart_is_driver_installed(CONFIG_GSM_UART_NUM))
        uart_driver_delete(CONFIG_GSM_UART_NUM);
    gpio_set_direction(CONFIG_GSM_UART_GPIO_TX, GPIO_MODE_OUTPUT);
    gpio_set_direction(CONFIG_GSM_UART_GPIO_RX, GPIO_MODE_INPUT);
    gpio_set_pull_mode(CONFIG_GSM_UART_GPIO_RX, GPIO_PULLUP_ONLY);
    const uart_config_t uart_config =
        .baud_rate = CONFIG_GSM_UART_BAUDRATE,
        .data_bits = UART_DATA_8_BITS,
        .parity = UART_PARITY_DISABLE,
        .stop_bits = UART_STOP_BITS_1,
        .flow_ctrl = UART_HW_FLOWCTRL_DISABLE
    uart_param_config(CONFIG_GSM_UART_NUM, &uart_config);
    uart_set_pin(CONFIG_GSM_UART_NUM, CONFIG_GSM_UART_GPIO_TX, CONFIG_GSM_UART_GPIO_RX, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE);
    uart_driver_install(CONFIG_GSM_UART_NUM, CONFIG_GSM_BUF_SIZE, CONFIG_GSM_BUF_SIZE, 0, NULL, 0);
    while (1)
        ESP_LOGI("[GSM]","modem init start");
        gpio_set_level(CONFIG_GSM_PWR_ON, 1);
        vTaskDelay(10 / portTICK_PERIOD_MS);
#if (CONFIG_GSM_PWR_KEY > 0)
        gpio_set_level(CONFIG_GSM_PWR_KEY, 0);
        vTaskDelay(1500 / portTICK_PERIOD_MS);
        gpio_set_level(CONFIG_GSM_PWR_KEY, 1);
#endif
        int i;
        for (i = 0; i < 60; i++)
            const int rc = send_cmd(CONFIG_GSM_UART_NUM, "AT\r\n", "OK", "0", 1000);
            if (1 == rc || 2 == rc)
                break;
        if (i == 60)
            ESP_LOGE("[GSM]","modem not answer");
            continue;
            ESP_LOGI("[GSM]","modem found");
        send_cmd(CONFIG_GSM_UART_NUM, "AT+CNUM\r\n", "OK", "0", 500);
#endif
            const int r = send_cmd(CONFIG_GSM_UART_NUM, "AT+CREG?\r\n", "+CREG: 0,1", "+CREG: 0,5", 1000);
            if (r == 1 || r == 2)
                break;
        if (i == 60)
            ESP_LOGE("[GSM]","modem not registering");
            continue;
            ESP_LOGI("[GSM]","modem registration OK");
        vTaskDelay(2500 / portTICK_PERIOD_MS);
        send_cmd(CONFIG_GSM_UART_NUM, "AT+CGDCONT=1,\"IP\",\"internet\"\r\n", "OK", NULL, 500);
        vTaskDelay(4000 / portTICK_PERIOD_MS);
        if (1 == send_cmd(CONFIG_GSM_UART_NUM, "ATD*99#\r\n", "CONNECT", "ERROR", 15000))
            ESP_LOGI("[GSM]","modem connected");
            memset(&ppp_netif, 0, sizeof(ppp_netif));
            ppp = pppapi_pppos_create(&ppp_netif, p_output_callback, p_status_cb, NULL);
            pppapi_set_default(ppp);
            pppapi_connect(ppp, 0);
            uint8_t d1[CONFIG_GSM_BUF_SIZE];
            while (1)
                const int len = uart_read_bytes(CONFIG_GSM_UART_NUM, d1, CONFIG_GSM_BUF_SIZE, 10 / portTICK_PERIOD_MS);
                if (len)
                    pppos_input_tcpip(ppp, (u8_t*)d1, len);
            ESP_LOGE("[GSM]","modem can't connect");
    if (ppp)
        ESP_LOGI("[GSM]","disable PPP interface");
        pppapi_close(ppp, 0);
        pppapi_free(ppp);
        ppp = NULL;
    if (modem_task)
        ESP_LOGI("[GSM]","restart modem task");
        vTaskDelete(modem_task);
        modem_task = NULL;
    xTaskCreate(gsm_task,
                "gsm_task",
                4096 * 2,
                NULL,
                4,
                &modem_task);
static void log_error_if_nonzero(const char *message, int error_code)
    if (error_code != 0)
        ESP_LOGE(MQTTTAG, "Last error %s: 0x%x", message, error_code);
    ESP_LOGD(MQTTTAG, "Event dispatched from event loop base=%s, event_id=%" PRIi32 "", base, event_id);
    esp_mqtt_event_handle_t event = event_data;
    esp_mqtt_client_handle_t client = event->client;
    char s[64];
    switch ((esp_mqtt_event_id_t)event_id) {
        case MQTT_EVENT_BEFORE_CONNECT:
            ESP_LOGI(MQTTTAG, "MQTT_EVENT_BEFORE_CONNECT");
            break;
            ESP_LOGI(MQTTTAG, "MQTT_EVENT_CONNECTED");
            esp_mqtt_client_subscribe(client, "downlink/#", 0);
            cJSON *root;
            root = cJSON_CreateObject();
            cJSON_AddItemToObject(root, "tmpl",  cJSON_CreateString(CONFIG_BLYNK_TEMPLATE_ID));
            cJSON_AddItemToObject(root, "ver",   cJSON_CreateString(CONFIG_BLYNK_FIRMWARE_VERSION));
            cJSON_AddItemToObject(root, "build", cJSON_CreateString(__DATE__ " " __TIME__));
            cJSON_AddItemToObject(root, "type",  cJSON_CreateString(CONFIG_BLYNK_FIRMWARE_TYPE));
            cJSON_AddNumberToObject(root, "rxbuff", 512);
            char *rendered=cJSON_Print(root);
            esp_mqtt_client_publish(client, "info/mcu", rendered, 0, 1, 0);
            free(rendered);
            cJSON_Delete(root);
            snprintf(s, sizeof(s), "%d", rand() % 100);
            esp_mqtt_client_publish(client, "ds/Random", s, 0, 1, 0);
            break;
        case MQTT_EVENT_SUBSCRIBED:
            ESP_LOGI(MQTTTAG, "MQTT_EVENT_SUBSCRIBED, msg_id=%d", event->msg_id);
            break;
        case MQTT_EVENT_DISCONNECTED:
            ESP_LOGI(MQTTTAG, "MQTT_EVENT_DISCONNECTED");
            if (!mqtt_offline_timestamp)
                ESP_LOGI(MQTTTAG, "just got offline");
                mqtt_offline_timestamp = xTaskGetTickCount();
                const TickType_t now = xTaskGetTickCount();
                const int offline_seconds = (now - mqtt_offline_timestamp) * portTICK_PERIOD_MS / 1000;
                const int gsm_reinit = offline_seconds >= 180;
                ESP_LOGI(MQTTTAG, "offline already %d seconds %s", offline_seconds, gsm_reinit ? "rebooting gsm" : "");
                if (gsm_reinit)
                    mqtt_offline_timestamp = now;
                    gsm_init();
            break;
        case MQTT_EVENT_UNSUBSCRIBED:
            ESP_LOGI(MQTTTAG, "MQTT_EVENT_UNSUBSCRIBED, msg_id=%d", event->msg_id);
            break;
        case MQTT_EVENT_PUBLISHED:
            ESP_LOGI(MQTTTAG, "MQTT_EVENT_PUBLISHED, msg_id=%d", event->msg_id);
            break;
        case MQTT_EVENT_DATA:
            ESP_LOGI(MQTTTAG, "MQTT_EVENT_DATA");
            const char ota_topic_name[] = "downlink/ota/json";
            const size_t ota_topic_len = strlen(ota_topic_name);
            const char redir_topic_name[] = "downlink/redirect";
            const size_t redir_topic_len = strlen(redir_topic_name);
            if ((event->topic_len >= ota_topic_len)
                && !memcmp(event->topic, ota_topic_name, ota_topic_len))
                ESP_LOGI("[OTA]", "start");
                cJSON *root = cJSON_ParseWithLength(event->data, event->data_len);
                ESP_LOGI("[OTA]", "url[%s]", cJSON_GetObjectItem(root, "url")->valuestring);
                ESP_LOGI("[OTA]", "size[%d]", cJSON_GetObjectItem(root, "size")->valueint);
                ESP_LOGI("[OTA]", "type[%s]", cJSON_GetObjectItem(root, "type")->valuestring);
                ESP_LOGI("[OTA]", "ver[%s]", cJSON_GetObjectItem(root, "ver")->valuestring);
                ESP_LOGI("[OTA]", "build[%s]", cJSON_GetObjectItem(root, "build")->valuestring);
                esp_http_client_config_t config = {
                    .url = cJSON_GetObjectItem(root, "url")->valuestring,
                    .cert_pem = (char *)CA_CERT,
                    .keep_alive_enable = true,
                esp_https_ota_config_t ota_config = {
                    .http_config = &config,
                ESP_LOGI("[OTA]", "Attempting to download update from %s", config.url);
                esp_err_t ret = esp_https_ota(&ota_config);
                if (ret == ESP_OK) {
                    ESP_LOGI("[OTA]", "OTA Succeed, Rebooting...");
                    esp_restart();
                    ESP_LOGE("[OTA]", "Firmware upgrade failed [%d]", ret);
                cJSON_Delete(root);
            else if ((event->topic_len >= redir_topic_len)
                    && !memcmp(event->topic, redir_topic_name, redir_topic_len))
                ESP_LOGI(MQTTTAG, "got redirect to [%.*s]", event->data_len, event->data);
                char *uri = malloc(event->data_len + 128);
                if (uri)
                    memcpy(uri, event->data, event->data_len);
                    uri[event->data_len] = '\0';
                    char prot[32];
                    char addr[128];
                    int port;
                    while (strchr(uri, '/'))
                        *(char*)strchr(uri, '/') = ' ';
                    while (strchr(uri, ':'))
                        *(char*)strchr(uri, ':') = ' ';
                    if (3 == sscanf(uri, "%s %s %d", prot, addr, &port))
                        uri[0] = '\0';
                        if (!strcmp(prot, "tls") || !strcmp(prot, "mqtts"))
                            strcat(uri, "mqtts://");
#endif
                        if (!strcmp(prot, "tcp") || !strcmp(prot, "mqtt"))
                            strcat(uri, "mqtt://");
                        if (!strcmp(prot, "ws") || !strcmp(prot, "wss"))
                            sprintf(uri, "%s://", prot);
                        if (!strstr(uri, "://"))
                            ESP_LOGE(MQTTTAG, "wrong protocol [%s]", prot);
                            char t[34];
                            size_t l = sizeof(t);
                            if (ESP_OK != get_nvs_blynk_auth_token(t, &l))
                                ESP_LOGE(MQTTTAG, "Can't read auth token. please configure it and reboot");
                            sprintf(uri + strlen(uri), "device:%s@%s:%u", t, addr, port);
                            const esp_err_t r0 = esp_mqtt_client_disconnect(client);
                            const esp_err_t r1 = esp_mqtt_client_set_uri(client, uri);
                            if (ESP_OK != r1 || ESP_OK != r0)
                                ESP_LOGE(MQTTTAG, "can't redirect to [%s] [%s] [%s]", uri,  esp_err_to_name(r0), esp_err_to_name(r1));
                        ESP_LOGE(MQTTTAG, "malformed redirect address [%.*s]", event->data_len, event->data);
                    free(uri);
                    ESP_LOGE(MQTTTAG, "can't allocate uri");
            ESP_LOGI(MQTTTAG, "TOPIC=%.*s", event->topic_len, event->topic);
            ESP_LOGI(MQTTTAG, "DATA=%.*s", event->data_len, event->data);
            break;
        case MQTT_EVENT_ERROR:
            ESP_LOGI(MQTTTAG, "MQTT_EVENT_ERROR");
            if (event->error_handle->error_type == MQTT_ERROR_TYPE_TCP_TRANSPORT) {
                log_error_if_nonzero("reported from esp-tls", event->error_handle->esp_tls_last_esp_err);
                log_error_if_nonzero("reported from tls stack", event->error_handle->esp_tls_stack_err);
                log_error_if_nonzero("captured as transport's socket errno",  event->error_handle->esp_transport_sock_errno);
                ESP_LOGI(MQTTTAG, "Last errno string (%s)", strerror(event->error_handle->esp_transport_sock_errno));
            break;
        default:
            ESP_LOGI(MQTTTAG, "Other event id:%d", event->event_id);
            break;
static esp_mqtt_client_handle_t* mqtt_app_start(void)
    esp_mqtt_client_config_t mqtt_cfg = {};
    char uri[256];
    if (!starts_with(CONFIG_BLYNK_TEMPLATE_ID, "TMPL") ||
        !strlen(CONFIG_BLYNK_TEMPLATE_NAME)
        ESP_LOGE(MQTTTAG, "Invalid configuration of TEMPLATE_ID / TEMPLATE_NAME");
        return NULL;
    char t[34];
        return NULL;
    snprintf(uri, sizeof(uri), "mqtts://device:%s@%s:8883", t, CONFIG_BLYNK_SERVER);
    mqtt_cfg.broker.verification.certificate = (const char *)CA_CERT;
#else
    snprintf(uri, sizeof(uri), "mqtt://device:%s@%s:1883", t, CONFIG_BLYNK_SERVER);
#endif
    uri[sizeof(uri) - 1] = '\0';
    mqtt_cfg.broker.address.uri = uri;
    // mqtt_cfg.network.disable_auto_reconnect = true;
    esp_mqtt_client_handle_t *client = malloc(sizeof(esp_mqtt_client_handle_t));
    if (client)
        *client = esp_mqtt_client_init(&mqtt_cfg);
        if (ESP_OK != esp_mqtt_client_register_event(*client, ESP_EVENT_ANY_ID, mqtt_event_handler, NULL) ||
            ESP_OK != esp_mqtt_client_start(*client))
            free(client);
            client = NULL;
    return client;
static void brd_init(void)
    const gpio_config_t io_conf =
        .intr_type = GPIO_INTR_DISABLE,
        .mode = GPIO_MODE_OUTPUT,
        .pin_bit_mask = ((1ULL<<CONFIG_GSM_PWR_KEY) | (1ULL<<CONFIG_GSM_PWR_ON)),
#else
        .pin_bit_mask = ((1ULL<<CONFIG_GSM_PWR_ON)),
#endif
        .pull_down_en = 0,
        .pull_up_en = 0,
    gpio_config(&io_conf);
int nvs_init(void)
    esp_err_t err = nvs_flash_init();
    if (err == ESP_ERR_NVS_NO_FREE_PAGES || err == ESP_ERR_NVS_NEW_VERSION_FOUND) {
        ESP_ERROR_CHECK(nvs_flash_erase());
    return ESP_OK != err;
static int blynk_cmd_cb(int argc, char **argv)
    if (argc == 2)
        printf("%s\n", set_nvs_blynk_auth_token(argv[1]) ? "error" : "ok");
        printf("wrong usage\n");
    return 0;
typedef struct {
    struct arg_str *token;
    struct arg_end *end;
} auth_cmd_t;
static esp_console_cmd_t auth_cmd = {};
static auth_cmd_t auth_cmd_args = {};
    esp_console_repl_t *repl = NULL;
    esp_console_repl_config_t repl_config = ESP_CONSOLE_REPL_CONFIG_DEFAULT();
    repl_config.prompt = "BLYNK>";
    repl_config.max_cmdline_length = 256;
    auth_cmd_args.token = arg_str0(NULL, NULL, "REDACTED", "blynk auth token");
    auth_cmd_args.end = arg_end(1);
    auth_cmd.command = "set_auth_token";
    auth_cmd.help = "blynk token configuration";
    auth_cmd.hint = NULL;
    auth_cmd.func = &blynk_cmd_cb;
    auth_cmd.argtable = &auth_cmd_args;
    esp_console_cmd_register(&auth_cmd);
    const esp_console_dev_uart_config_t hw_config = ESP_CONSOLE_DEV_UART_CONFIG_DEFAULT();
    esp_console_new_repl_uart(&hw_config, &repl_config, &repl);
    esp_console_start_repl(repl);
void app_main()
     * Embed the info tag into the MCU firmware binary
     * This structure is used to identify the firmware type
     * and version during the OTA upgrade
    volatile const char firmwareTag[] = "blnkinf\0"
    BLYNK_PARAM_KV("mcu"    , CONFIG_BLYNK_FIRMWARE_VERSION)       // Primary MCU: firmware version
    BLYNK_PARAM_KV("fw-type", CONFIG_BLYNK_FIRMWARE_TYPE)          // Firmware type (usually same as Template ID)
    BLYNK_PARAM_KV("build"  , __DATE__ " " __TIME__)               // Firmware build date and time
    "\0";
    (void)firmwareTag;
    brd_init();
    nvs_init();
    register_auth_key_cmd();
    esp_netif_init();
    gsm_init();
    mqtt_app_start();
    while (1)
        vTaskDelay(1000 / portTICK_PERIOD_MS);
  1. This is the output of the serial monitor:
3.Regarding the device auth token, the code does it in the following function register_auth_key_cmd(), which in turn, it is invoked by app_main(). Also, the command was provided manually in the serial monitor as indicated in the instructions:
BLYNK> set_auth_token MY-DEVICE-AUTH-TOKEN with no successful result.
Again, an apology for the incorrect initial posting.
Thanks a lot for your comments, and insight.
I’m more confused by your second post than by your first.
You’ve not said what modem config you are using, and how you’ve determined that this is specifying the correct GPIO pins for your particular board.
And, despite me asking you to post your serial output as text with triple backticks, you’ve posted a screenshot.
If the contents of your screenshot are all you are seeing when you boot your board then I’d guess that you have a hardware problem.
I don’t have your hardware, or use ESP-IDF so I’m somewhat in the dark about exactly how the example works, but getting the correct Blynk credentials and correct modem settings configured are the key to making progress with the project.
Pete,
Thanks for your insight.
The issue is solved.
An apology for the incorrect presentation of data, I will improve it.
For sure, I will be back, if any further question comes up on coming steps.
There is a lot to learn.
Again, thanks a lot for your attention.
Carlos
