Hello all,
After a lot of Googling, I still can’t figure this out. I am working on a project where I want to have an automatic routine run while allowing for manual control through the Blynk app. I want to turn off the auto routine when manual mode is turned on through the app. Please take a look and let me know if you have a suggestion.
Thanks!
Hardware model + communication type: Arduino UNO with Ethernet 2 Shield
Android)
Blynk server
Social networks: http://www.fb.com/blynkapp
http://twitter.com/blynk_app
This example shows how to use Arduino Ethernet Shield 2 (W5500)
to connect your project to Blynk.
Note: This requires Ethernet2 library
from http://librarymanager/all#Ethernet2
Pins 10, 11, 12 and 13 are reserved for Ethernet module.
DON'T use them in your sketch directly!
#include <Ethernet2.h>
#include <BlynkSimpleEthernet2.h>
char auth[] = "**********************************iiV7";
int Blynk_controlU = 7; //Digital Pin 5 is for Blynk manual Mode "UP"
int Blynk_controlD = 8; //Digital Pin 8 is for Blynk manual Mode "Down"
int Blynk_controlMANUAL = 5; // Digital Pin 7 is for Blynk Manual Mode
int trigger = 3; //Digital Pin 3 is Trigger for manual mode
int Auto_ControlU = 6; //Digital Pin 6 is for Auto Control "UP"
int Auto_ControlD = 9; //Digital Pin 9 is for Auto Control "DOWN"
void routine_manual()
{digitalWrite(Auto_ControlU, LOW);
digitalWrite(Auto_ControlD, LOW);}
void routine_auto()
{digitalWrite(Auto_ControlU, HIGH);
digitalWrite(Auto_ControlD, HIGH);
delay(1000);}
pinMode(Blynk_controlU,OUTPUT);
pinMode(Blynk_controlD,OUTPUT);
pinMode(Blynk_controlMANUAL,OUTPUT);
pinMode(trigger,INPUT);
pinMode(Auto_ControlU,OUTPUT);
pinMode(Auto_ControlD,OUTPUT);
timer.setInterval(1000L,TimerEvent);
Blynk.begin(auth);
//Blynk.begin(auth, "blynk-cloud.com", 80);
//Blynk.begin(auth, IPAddress(192,168,1,100), 8080);
// For more options, see Boards_Ethernet/Arduino_Ethernet_Manual example
void TimerEvent(){
if (digitalRead(trigger == 1)){
routine_manual();
}else{
routine_auto();
Serial.println(digitalRead(trigger));
