Using Automation to trigger a notification when value does not change with in a set period
I love Blynk. I have a pump that is normally off for 20 min (0psi) and then turns on for 1 min which brings the pressure to (40 psi) and repeats this behavior over and over. I would like to create an automation to to send a notification if this does not happen. For example if the pump pressure did not reach 40psi with in the hour I could be notified. I am getting stuck trying to figure out how to notify if pump does not cycle. Can this be done with an automation or other feature on the Blynk dashboard or do I have to add to the code of the micro controller? Thanks
