Ha… I don’t know… I am all bossy, not all knowing (shush, don’t tell anyone )
I thought that this was a system wide expansion of vPins for normal use, not a partial update that has strange use cases and rules. But then even with my MEGA testbench, I never exceed 80 consecutive vPins anyhow so I never looked into it until I saw this topic.
No it does not work
The fact that it compiles doesn’t mean it works.
yes , it does not work, nothing is displayed on my label widget , really bad
Hello @vshymanskyy @Dmitry I am just curious if this functionality will be released on the next Blynk Library maybe V0.5.5?
Please read my comments above. Especially:
The BLYNK_WRITE_DEFAULT() function handle virtual write for all pins > 127, this is a small example to manage pins 181 and 190:
int pin = request.pin; // Which pin has trigger write
int value = param.asInt(); // Use param as usual.
//only for debug
Serial.print("virtual write pin: ");
Serial.print(pin);
Serial.print(" value: ");
Serial.println(value);
//handle pins actions
switch(pin){
case 181:
//your custom code for pin 181
Serial.println("TODO 181");
break;
case 190:
//your custom code for pin 190
Serial.println("TODO 190");
break;
Best Regards
