Hi
i try to control a curtain with ac motor. I use NodeMCU 12E and AC Dimmer with Blynk
This is the code for AC Dimmer using Arduino Board.
To watch it's full tutorial video, head on to my YouTube Channel
http://www.youtube.com/techiesms
//#define BLYNK_DEBUG
#define BLYNK_TEMPLATE_ID "TMPL2sBtHPSFl"
#define BLYNK_TEMPLATE_NAME "acDimmer"
#define BLYNK_AUTH_TOKEN "duXuu137r5_aEaiLOiWhzbUL7VrOw3NH"
#define triacPulse 5 //D1
#define ZVC 4 //D2
int Slider_Value;
int dimming;
int x = 0;
char auth[] = "duXuu137r5_aEaiLOiWhzbUL7VrOw3NH"; // You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon) in the Blynk app or check your email for auth token.
//char ssid[] = "ArduinoCS"; // Your WiFi credentials.
//char pass[] = "02151627"; // Set password to "" for open networks.
char ssid[] = "Helals"; // Your WiFi credentials.
char pass[] = "Moneim&46&Atiat"; // Set password to "" for open networks.
BLYNK_WRITE(V1) // function to assign value to variable Slider_Value whenever slider changes position
Slider_Value = param.asInt(); // assigning incoming value from pin V1 to a variable
pinMode(ZVC, INPUT_PULLUP);
//digitalWrite(2, INPUT_PULLUP); // pull up
pinMode(triacPulse, OUTPUT);
//Blynk.begin(auth, ssid, pass, "blynk.cloud", 8080);
attachInterrupt(digitalPinToInterrupt(ZVC), acon, FALLING); // attach Interrupt at PIN2
// When the switch is closed
dimming = map(Slider_Value, 0, 100, 7200, 200); //0.2ms 7.2 ms
void acon()
// Serial.println("REad");
delayMicroseconds(dimming); // read AD0
digitalWrite(triacPulse, HIGH);
delayMicroseconds(50); //delay 50 uSec on output pulse to turn on triac
digitalWrite(triacPulse, LOW);
// Serial.println(digitalRead(triacPulse));
the esp8266 connects to the blynk app but i get the below results
���e�'�{��n<�$�d`c��|r�l�g��g�d`��;�d�d��[79] Connecting to Helals
[7413] Connected to WiFi
[7413] IP: 192.168.1.8
[7413]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v1.3.2 on ESP8266
#StandWithUkraine https://bit.ly/swua
[7423] Connecting to blynk.cloud:80
[7698] Ready (ping: 131ms).
ISR not in IRAM!
User exception (panic/abort/assert)
>>>stack>>>
ctx: cont
sp: 3fffff80 end: 3fffffd0 offset: 0010
3fffff90: 402078fc 0801a8c0 00000004 40204de1
3fffffa0: feefeffe feefeffe feefeffe 3ffeed90
3fffffb0: 3fffdad0 00000000 3ffeed64 40204420
3fffffc0: feefeffe feefeffe 3fffdab0 40100f91
<<<stack<<<
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
ets Jan 8 2013,rst cause:2, boot mode:(3,7)
load 0x4010f000, len 3424, room 16
tail 0
chksum 0x2e
load 0x3fff20b8, len 40, room 8
tail 0
chksum 0x2b
csum 0x2b
v000469b0
any help to fix this error
