Use webhook to PUT data to google sheets?
I don’t have time right now. But I’ll have a look in few weeks what we can do. Maybe we can add some kind of OAth integration.
@Dmytro I can send the data from one pin to the Google sheet with the following in the body:
{“Date”:["/pin/"]}
but I need to add data for perhaps 3 or 4 more columns.
In your docs you have:
You can also refer to specific index of multi value pin :
/pin0/,/pin1/, /pin2/
I tried with the menu widget that is a “multiple value pin” but didn’t get very far. Are there any other widgets that have multiple values?
Maybe I have discount because I am not a new user. I use it for a long time to send an email for alarms (temperature over limit, alarm system notifications).
@aquarius are you using the body or were you able to use parameters in the Webhook url?
I couldn’t get it to work with the url. I would prefer everything in the url rather than messing about with the body.
@Costas, no, I used the pure URL which was created by Zapier and write to body this:
“value”:"/pin/"
Pin value inserted after every refresh to my spreadsheet “value” column.
not?
“value”:["/pin/"]
I did not use [ ] brackets.
Not sure why you need widget for webhook. If you want to insert multiple values to google you need to :
Blynk.virtualWrite(V1, val1, val2, val3);
and in webhook : /pin0/,/pin1/, /pin2/.
where pin0 is val1, pin1 is val2, etc
is it max number of value is 3? can add more like 4 or 5 values?
5 values is max.
1 is the maximum for me. @Dmytro’s syntax wouldn’t work in the body and I tried for many hours. Did you get more than 1 parameter working?
I need “CardID”, “Name”, “Door”, “Room”, “Date-Time”. So 5 is what I need :slight_smile:, quite a lucky. Yesterday I think only 3
Sorry. Should be
/pin[0]/, /pin[1]/, etc
fixed docs accordingly.
Perhaps 4?
Indexes [0, 4] inclusively.
@Dmytro but virtualWrite only appears to accept 4 variables.
You are right. Created ticket https://github.com/blynkkk/blynk-library/issues/225
@NHN five column private Google sheet updated with Blynk Webhook widget via Zapier:
Date	        Hardware Time          ID	Data
01/11/2016	    ESP	 10:29.15	0	26.23
01/11/2016	    ESP	 10:33:47	1	23.20
01/11/2016	    ESP	 10:40:27	2	24.70
01/11/2016	    ESP	 10:43:50	3	24.70
01/11/2016	    ESP	 10:50:54	4	23.79
01/11/2016	    ESP	 10:54:58	5	24.70
I cheated with the Date column as that is just “01/11/2016” being sent rather than a Blynk variable.
The plan costs from Zapier at 3000 tasks per month (approx 100 entries per day) is currently what I consider to be excessive at $50 so it’s not a service I would promote. Last night I registered one of my domains with Google so I’ll see if I can get the private sheets working directly without Zapier.
@Costas did you try to write or edit data? I tried but not success.
No I didn’t try as I moved on to Zapier. Did you try Zapier?
Over the next few days I will try to update some of my sheets without Zapier via the Google authenticated domain. Will post when I have some results.
