Use millis instead of Delay
Hey guys, I´m still automating my appartment with Blynk :v:
Now, the illumination from the stairs have to believe in it.
Until now it works like this: When the PIR sensor detect someone, al LED-strip under the stairs fade slowly up. Later in additional I want get a message over Blynk that it got on. Until now it fades up with a delay inside the code which I needed to remove. My problem´s that it is inside a for-loop. Is there a possibility to remove and replace it with millis() ?
int ledPin = D5;
int brightness = 0;
void guydetected() {
  for (int i = -90; i < 90; i++) {
    float angle = radians(i);
    brightness = (255 / 2) + (255 / 2) * sin(angle);
    Serial.println(brightness);
    analogWrite(ledPin, brightness);
    delay(30);
You could have a timer that you call every 30ms to do a single step of the fading each time.
Here’s an example of Timer:
And some partial code that hopefully helps:
{  //Add the following line
timer.setInterval(30L, FadeLEDs);
int FadePosition = -90;
bool MotionDetected;
void FadeLEDs()
  if (MotionDetected)
     if(FadePosition < 90)
       FadePosition++;
       float angle = radians(FadePosition);
First of all: Thanks for your quick reply.
Second: error in line 16. (‘i’ was not declared in this scope)
If now I declare ‘i’ as an integer, equal if it´s -90 or 90 for exampe, I usually get a fix brightness value in Serial Monitore :confounded:
int i = 50;
int brightness = 0;
int ledPin = D5;
bool MotionDetected=1;
void FadeLEDs()
//  if (MotionDetected)
       FadePosition++;
I commented the if-condition only to test the sketch easier. :wink:
Serial Monitor shows me that the value of brightness is constant 224
I think you need to replace i with FadePosition
Also, does this give a brightness value of 0-255, or 0-1023?
Pete you are great!
I replaced i with FadePosition, now it fades up :see_no_evil:
