While I wait for a proper Lorawan Gateway arrive I’m attempting to display a temperature reading on a Blynk Web dashboard sent from one Arduino MKR 1310 to another that is then connected to an ESP32 WROOM board via the serial port.
There’s a similar project here but that uses MKR 1300s and an ESP8266.
I’ve used the below sketch to connect the ESP32 to Blynk successfully but I think I missing the correct code to take the temperature input coming from the serial output (working, tested) of the MKR 1310 receiver board.
// This code for ESP32 device
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#define BLYNK_TEMPLATE_ID "-"
#define BLYNK_TEMPLATE_NAME "-"
#define BLYNK_AUTH_TOKEN "-"
char auth[] = "-"; // Blynk authentication token
char ssid[] = "-"; // WiFi SSID
char pass[] = "-"; // WiFi password
BLYNK_WRITE(V0) {
float temperature = param.asFloat();
Serial.print("Received Temperature: ");
Serial.println(temperature);
Blynk.virtualWrite(V1, temperature); // Display temperature on the Value Display widget in Blynk app
This is the code from the link I’ve tried to update for the 1310 and ESP32:
#include<String.h>
#include <SoftwareSerial.h>//libraries needed in communicating with gps and nodemcu
int RXPin = D2;//tx pin of mkr1300 connected to this pin
int TXPin = D1;//rx pin of mkr1300 connected to this pin
SoftwareSerial data_serial(RXPin, TXPin);//declaring the rx,tx pins
int incomingByte = 0;
int data1;
int data2;
int data3;
int data4;
int data5;
String LoRaData;
String jsonBuffer;
float ta;// Temperature details
float ha; // Humidity details
float rs; //Rssi details
char auth[] = "xxxxxxxxxxxxx";// Your blynk app token id
char ssid[] = "xxxxxxxxxxxx"; // your Wifi name
char pass[] = "xxxxxxxxxxxxxxx"; // your wifi password
data_serial.begin(9600);
String str1="",str2="",str3="",str4="",str5="";
int i=0,len;
char commandbuffer[400];
if (data_serial.available())
delay(500);
while( data_serial.available() && i< 99)
commandbuffer[i++] = data_serial.read();
//commandbuffer[i++]='\0';
Serial.println((char*)commandbuffer);
str1=str1+((char*)commandbuffer);
len=str1.length();
Serial.println(len);
if(len-15 > 0)
str1=str1.substring(0,len);
str2=str1.substring(0,2);
str3 =str1.substring(3,5);
str4 = str1.substring(6,8);
str5 = str1.substring(9,15);
data1 = str2.toInt();
data2 = str3.toInt();
data3 = str4.toInt();
data4 = str5.toInt();
Serial.print("hum:");
Serial.print(data1);
Serial.println();
Serial.print("temp:");
Serial.print(data2);
Serial.println();
Serial.print("Light:");
Serial.print(data3);
Serial.println();
Serial.print("axis:");
Serial.print(data4);
Serial.println();
Blynk.virtualWrite(V0,data1);
Blynk.virtualWrite(V1,data2);
Blynk.virtualWrite(V2,data3);
Blynk.virtualWrite(V3,data4);
Any advice appreciated.
Nate
