Hi friends. is it possible to using Blynk.virtualWrite as BLYNK_WRITE ?
my code is
BLYNK_WRITE(V35)
if (param.asInt()) {
irsend.sendRaw(irTVpwr, sizeof(irTVpwr) / sizeof(irTVpwr[0]), khz);
//delay(40);
my code is
BLYNK_WRITE(V35)
//delay(40);
OK. I solved the problem by bridge widget
Can you show an example of how you solved it? I have a similar issue where I wish to update a virtual LED on board 1 with data received from board 2.
it’s very simple.
in two MCUs add this code in sketch:
WidgetBridge bridge1(V10);
in primary MCU add this code to sketch:
BLYNK_CONNECTED() {
bridge1.setAuthToken("second board Token ID");
and now you can update virtual pins and hardware pins on second mcu from primary mcu
when primary MCU pin V3 set to 1 then the V35 on secondary MCU set to 1
Blynk.virtualWrite(V3, 1);
bridge1.virtualWrite(V35, 1);
don’t forget to add bridge widget to your project
