USB connection problem (Received EOF; EVENT_CLOSE)
Hellow fellows :wink:
at the moment i want to controll a LED strip with my smartphone. Its a WS2812B strip and i copied some animations from the Adafruit Neopixel example. Some functions seem to cause a connection problem to the arduino.
Connect(β€œ192.168.0.18”, β€œ8442”) - OK
InOut() START
DSR is OFF
Received EOF
EVENT_CLOSE
InOut() - STOP
Disconnect() - OK
InOut() START
DSR is OFF
end so on.
The functions who cause the error are the rainbowCycle and theater
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
    for(i=0; i< strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
    strip.show();
    delay(wait);
//Theatre-style crawling lights.
void theaterChase(uint32_t c, uint8_t wait) {
  for (int j=0; j<10; j++) {  //do 10 cycles of chasing
    for (int q=0; q < 3; q++) {
      for (uint16_t i=0; i < strip.numPixels(); i=i+3) {
        strip.setPixelColor(i+q, c);    //turn every third pixel on
      strip.show();
      delay(wait);
        strip.setPixelColor(i+q, 0);        //turn every third pixel off
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
  WheelPos = 255 - WheelPos;
  if(WheelPos < 85) {
    return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  if(WheelPos < 170) {
    WheelPos -= 85;
    return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
  WheelPos -= 170;
  return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
Anyone an idea ?
Best wishes,
Mirgus
that’s right as documented on this site.
