I am trying to recompile the Particle Photon project using Blynk 0.5.2 library instead of 0.3.3. I use Particle Desktop Ide and I can’t compile the project. There are a lot of errors like this:
“‘WidgetTerminal’ does not math name a type”
example code: WidgetTerminal terminal(V7);
“‘Blynk’ was not declared in this scope”
exaple code: Blynk.virtualWrite(V1, valInChar);
The begging of my program is below:
#include "Adafruit_BMP085.h"
#include "SFE_TSL2561.h"
#include "Blynk.h"
#include "SimpleTimer.h"
#include "HTU21D.h"
#include "spark-dallas-temperature.h"
#include "MQTT.h"
#define DS_RESOLUTION 12
#define MQTT_ID "*****"
#define mqtt_user "*****"
#define mqtt_password "*****"
#define MQTT_TEMP "Weather/temp"
#define MQTT_PRES "Weather/pres"
#define MQTT_HUMI "Weather/humi"
#define MQTT_DEW "Weather/dew"
#define MQTT_LUX "Weather/lux"
#define MQTT_IN_TOPIC "WeatherIn"
#define IFTTT_EV "WeatherSt_IFTTT"
#define MSR_DELAY 5 // 5000 ms
STARTUP(System.enableFeature(FEATURE_RETAINED_MEMORY));
//WiFi.setCredentials("My_Router", "mypasswordishuge");
Adafruit_BMP085 bmp;
SFE_TSL2561 tsl = SFE_TSL2561();
HTU21D htu = HTU21D();
boolean Flag_5sec;
boolean Flag_1min;
boolean Flag_1hour;
DallasTemperature dallas(new OneWire(D2));
DeviceAddress dallas_addr;
retained boolean gain = false; // Gain setting, 0 = X1, 1 = X16;
retained unsigned char integration = 0; // 0, 1, 2, 3- manual
unsigned int ms; // Integration ("shutter") time in milliseconds
unsigned int data1;
unsigned int data2;
float temp_bmp;
float pres;
double lux;
boolean lux_good;
float humi;
float temp_htu;
float temp_dallas;
float dew_point;
float temp; // temp from dallas or other devices
//String PublStr; //String to store the sensor data; spark variable "result" to store sensor data string
const char *CELL_SEPARATOR = "|||"; // for Goggle speedshet
retained int16_t NumberOfResets;
String MyIPstring;
Best regards,
Peter.
