Updating ZERGBA widget color via REST API
Can I ask you for the correct syntax of color update in the ZERGBA plugin via REST API?
Best wishes :wink:
Are you using the ZeRGBa widget in Split or Merge modes?
In my projects I uses merge mode.
This should work:
server/auth/update/Vpin?value=255&value=255&value=255
Okay, thanks. All works fine. Problem solved.
Hi Pete,
How about in split mode.
Is there a way to do it?
Yes, with three separate API calls one after another.
