I am trying to set the “time input” widget values via a get request in order to set it with the google assistant in my phone with the help of “ifttt” app
i manged to update a virtual pin that way but i cannot manage to update the time input widget values
what is the right way (syntax)
i tried some thing like this:
http://blynk-cloud.com/4ae3851817194e2596cf1b7103603ef8/update/V10?startAt=300&stopAt=3900&tz=“Europe/Kiev”&days=“1,2,3”
but it didnt work for me
thanks in advance
Gunner
July 21, 2019, 7:21pm
2
Oleg_Pugach:
startAt=300
You can’t combine a variable and the data in this API format… try using just the data. Also you need the value= after the vPin?
http://blynk-cloud.com/4ae3851817194e2596cf1b7103603ef8/update/V10?value=300,3900,“Europe/Kiev”,“1,2,3”
And then change your AUTH code so others don’t mess with your project
it worked only one time and stopped working
it updated the timer but not with the correct values it set it up to start 00:05 stop 00:05 and no days were chosen.
now it doesnt work at all
Gunner
July 22, 2019, 11:27am
7
Oleg_Pugach:
So it worked or not, that one time?
If the issue was the interpretation of your values, then I recommend experimenting until you understand what is needed, both in value and positioning in the command. Focus on one value at a time, EG startAt until it works, then stopAt, and so on.
Also, don’t forget to change your Auth Code… who knows what others are sending to mess up your settings
hi thanks
actually now i dont think it worked
it isnt my actual auth code :-p
You need to do it like this:
http://blynk-cloud.com/auth_token/update/Vx?value=aa%00bb%00cc%00dd%00ee
aa - start time in seconds (OR sr - sunrise, ss - sunset)
bb - stop time in seconds
cc - timezone (written in words)
dd - days selected (separated by commas)
ee - timezone offset in seconds
Eg:
http://blynk-cloud.com/auth_token/update/V1?value=sr%003723%00Europe/London%001,5,6,7%003600
wauuuu!!! Thank you very much it works perfectly.
how did you knew to use “%00”? where is it written?
%00 is a null character when encoded in URL,
But I found it in another thread on here - use search, find answers
Edit: Thread here
i try to use a “time input” widget on android to set time on for example V7 and also i want to set this time on V7 via rest-api.
at first i set the time via android app. then read out via rest api and get, for example:
# curl -k --output - 'https://server/token/get/V7'
["58826Europe/Berlin7200"]
when i update via
curl -k --include --request PUT --header "Content-Type: application/json" --data-binary "[\"42380Europe\/Berlin7200\"]" 'https://server/token/update/V7'
i can get the new valu…
Thank you, but i meant were is it specified that i should use a null character
I don’t think it is. But it works
Edit: I found it, will post tomorrow as I’m not near a PC at the moment. It’s not written in documentation but it is in the code
Code as promised is here:
@Override
public boolean updateIfSame(int deviceId, short pin, PinType type, String value) {
if (super.updateIfSame(deviceId, pin, type, value)) {
String[] values = value.split(BODY_SEPARATOR_STRING);
if (values.length > 2) {
startAt = calcTime(values[0]);
stopAt = calcTime(values[1]);
tzName = StringToZoneId.parseZoneId(values[2]);
if (values.length == 3 || values[3].isEmpty()) {
days = null;
String[] daysString = values[3].split(",");
days = new int[daysString.length];
for (int i = 0; i < daysString.length; i++) {
days[i] = Integer.parseInt(daysString[i]);
return true;
return false;
private static int calcTime(String value) {
switch (value) {
case "ss" :
return SUNSET;
case "sr" :
return SUNRISE;
case "" :
return NEVER;
default :
return Integer.parseInt(value);
Taken from: /server/core/src/main/java/cc/blynk/server/core/model/widgets/ui/TimeInput.java
So as per my earlier post, it looks like the time offset is no longer used.
The part we are interested in is this line:
Which when we find where BODY_SEPERATOR_STRING is define, which is in: /server/utils/src/main/java/cc/blynk/utils/StringUtils.java
public static final char BODY_SEPARATOR = '\0';
public static final String BODY_SEPARATOR_STRING = String.valueOf(BODY_SEPARATOR);
We see that BODY_SEPERATOR_STRING is defined as ‘\0’ which is NULL but URL can’t encode ‘\0’, hence why we use %00.
Thank you very very much everything is understood and working.
Now i can set my time input widget via google assistant on my cell phone
