Updating a "Follow Me Cooler" Arduino project to use an ESP8266 wifi
Updating a “Follow Me Cooler” Arduino project to use an ESP8266 wifi
I came across this cool project for a “Follow Me Cooler” that uses Bluetooth on an Arduino and an old version of the Blynk platform. Since Blynk no longer supports Bluetooth, I am trying to substitute a NodeMCU 12e (ESP8266) with Wi-Fi to do the same thing.
I’ve added all required code to access the Blynk cloud and I can get a WiFi signal. All my devices are wired correctly. However, all I see in the serial monitor is this shown below.
10:24:38.079 ->
10:24:38.079 -> ets Jan 8 2013,rst cause:4, boot mode:(3,6)
10:24:38.079 ->
10:24:38.079 -> wdt reset
10:24:38.079 -> load 0x4010f000, len 3460, room 16
10:24:38.079 -> tail 4
10:24:38.079 -> chksum 0xcc
10:24:38.079 -> load 0x3fff20b8, len 40, room 4
10:24:38.079 -> chksum 0xc9
10:24:38.126 -> csum 0xc9
10:24:38.126 -> v000499b0
10:24:38.126 -> ~ld
10:24:38.173 -> ------------------------------------
10:24:38.173 -> Sensor: HMC5883
10:24:38.173 -> Driver Ver: 1
10:24:38.173 -> Unique ID: 12345
10:24:38.173 -> Max Value: 800.00 uT
10:24:38.173 -> Min Value: -800.00 uT
10:24:38.173 -> Resolution: 0.20 uT
10:24:38.173 ->
Has anyone ever tried this? If so, what changes do you recommend? Below is my actual code. Any help is greatly appreciated.
Thank you.
//Blynk Template settings
#define BLYNK_TEMPLATE_ID "BLYNK_TEMPLATE_ID"
#define BLYNK_DEVICE_NAME "Cooler Quickstart Template"
#define BLYNK_AUTH_TOKEN "BLYNK_AUTH_TOKEN"
// Imports
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_HMC5883_U.h>
#include <Servo.h>
#include <TinyGPS.h>                 // Use local version of this library
#include <CoolerDefinitions.h>
#ifndef STASSID
#define STASSID "your_network"
#define STAPSK  "your_password"
#endif
const char* ssid     = STASSID;
const char* password = STAPSK;
// void setup() {
// GPS
TinyGPS gps;
// Lid
Servo lidServo;
// CoolerLid lidState = CLOSED;
// Master Enable
bool enabled = false;
//WidgetTerminal terminal(V3);
// Serial components
SoftwareSerial bluetoothSerial(BLUETOOTH_TX_PIN, BLUETOOTH_RX_PIN);
SoftwareSerial nss(GPS_TX_PIN, 255);            // TXD to digital pin 6
/* Compass */
Adafruit_HMC5883_Unified mag = Adafruit_HMC5883_Unified(12345);
GeoLoc checkGPS() {
  Serial.println("Reading onboard GPS: ");
  bool newdata = false;
  unsigned long start = millis();
  while (millis() - start < GPS_UPDATE_INTERVAL) {
    if (feedgps())
      newdata = true;
  if (newdata) {
    return gpsdump(gps);
  GeoLoc coolerLoc;
  coolerLoc.lat = 0.0;
  coolerLoc.lon = 0.0;
  return coolerLoc;
// Get and process GPS data
GeoLoc gpsdump(TinyGPS &gps) {
  float flat, flon;
  unsigned long age;
  gps.f_get_position(&flat, &flon, &age);
  GeoLoc coolerLoc;
  coolerLoc.lat = flat;
  coolerLoc.lon = flon;
  Serial.print(coolerLoc.lat, 7); Serial.print(", "); Serial.println(coolerLoc.lon, 7);
  Serial.print("CoolerLoc");
  return coolerLoc;
// Feed data as it becomes available
bool feedgps() {
  while (nss.available()) {
    if (gps.encode(nss.read()))
      return true;
  return false;
// Lid Hook
//BLYNK_WRITE(V0) {
//  switch (lidState) {
//    case OPENED:
//      setServo(SERVO_LID_CLOSE);
//      lidState = CLOSED;
//      break;
//    case CLOSED:
//      setServo(SERVO_LID_OPEN);
//      lidState = OPENED;
//      break;
// Killswitch Hook
BLYNK_WRITE(V1) {
  enabled = !enabled;
  //Stop the wheels
  stop();
// GPS Streaming Hook
BLYNK_WRITE(V2) {
  GpsParam gps(param);
  Serial.println("Received remote GPS: ");
  // Print 7 decimal places for Lat
  Serial.print(gps.getLat(), 7); Serial.print(", "); Serial.println(gps.getLon(), 7);
  GeoLoc phoneLoc;
  phoneLoc.lat = gps.getLat();
  phoneLoc.lon = gps.getLon();
  driveTo(phoneLoc, GPS_STREAM_TIMEOUT);
// Terminal Hook
BLYNK_WRITE(V3) {
  Serial.print("Received Text: ");
  Serial.println(param.asStr());
  String rawInput(param.asStr());
  int colonIndex;
  int commaIndex;
  do {
    commaIndex = rawInput.indexOf(',');
    colonIndex = rawInput.indexOf(':');
    if (commaIndex != -1) {
      String latStr = rawInput.substring(0, commaIndex);
      String lonStr = rawInput.substring(commaIndex+1);
      if (colonIndex != -1) {
         lonStr = rawInput.substring(commaIndex+1, colonIndex);
      float lat = latStr.toFloat();
      float lon = lonStr.toFloat();
      if (lat != 0 && lon != 0) {
        GeoLoc waypoint;
        waypoint.lat = lat;
        waypoint.lon = lon;
        Serial.print("Waypoint found: "); Serial.print(lat); Serial.println(lon);
        driveTo(waypoint, GPS_WAYPOINT_TIMEOUT);
    rawInput = rawInput.substring(colonIndex + 1);
  } while (colonIndex != -1);
void displayCompassDetails(void)
  sensor_t sensor;
  mag.getSensor(&sensor);
  Serial.println("------------------------------------");
  Serial.print  ("Sensor:       "); Serial.println(sensor.name);
  Serial.print  ("Driver Ver:   "); Serial.println(sensor.version);
  Serial.print  ("Unique ID:    "); Serial.println(sensor.sensor_id);
  Serial.print  ("Max Value:    "); Serial.print(sensor.max_value); Serial.println(" uT");
  Serial.print  ("Min Value:    "); Serial.print(sensor.min_value); Serial.println(" uT");
  Serial.print  ("Resolution:   "); Serial.print(sensor.resolution); Serial.println(" uT");
  Serial.println("");
  delay(500);
#ifndef DEGTORAD
#define DEGTORAD 0.0174532925199432957f
#define RADTODEG 57.295779513082320876f
#endif
float geoBearing(struct GeoLoc &a, struct GeoLoc &b) {
  float y = sin(b.lon-a.lon) * cos(b.lat);
  float x = cos(a.lat)*sin(b.lat) - sin(a.lat)*cos(b.lat)*cos(b.lon-a.lon);
  return atan2(y, x) * RADTODEG;
float geoDistance(struct GeoLoc &a, struct GeoLoc &b) {
  const float R = 6371000; // km
  float p1 = a.lat * DEGTORAD;
  float p2 = b.lat * DEGTORAD;
  float dp = (b.lat-a.lat) * DEGTORAD;
  float dl = (b.lon-a.lon) * DEGTORAD;
  float x = sin(dp/2) * sin(dp/2) + cos(p1) * cos(p2) * sin(dl/2) * sin(dl/2);
  float y = 2 * atan2(sqrt(x), sqrt(1-x));
  return R * y;
float geoHeading() {
  /* Get a new sensor event */
  sensors_event_t event;
  mag.getEvent(&event);
  // Hold the module so that Z is pointing 'up' and you can measure the heading with x&y
  // Calculate heading when the magnetometer is level, then correct for signs of axis.
  float heading = atan2(event.magnetic.y, event.magnetic.x);
  // Offset
  heading -= DECLINATION_ANGLE;
  heading -= COMPASS_OFFSET;
  // Correct for when signs are reversed.
  if(heading < 0)
    heading += 2*PI;
  // Check for wrap due to addition of declination.
  if(heading > 2*PI)
    heading -= 2*PI;
  // Convert radians to degrees for readability.
  float headingDegrees = heading * 180/M_PI;
  // Map to -180 - 180
  while (headingDegrees < -180) headingDegrees += 360;
  while (headingDegrees >  180) headingDegrees -= 360;
  return headingDegrees;
void setServo(int pos) {
  lidServo.attach(SERVO_PIN);
  lidServo.write(pos);
  delay(2000);
  lidServo.detach();
void setSpeedMotorA(int speed) {
  digitalWrite(MOTOR_A_IN_1_PIN, LOW);
  digitalWrite(MOTOR_A_IN_2_PIN, HIGH);
  // set speed to 200 out of possible range 0~255
  analogWrite(MOTOR_A_EN_PIN, speed + MOTOR_A_OFFSET);
void setSpeedMotorB(int speed) {
  digitalWrite(MOTOR_B_IN_1_PIN, LOW);
  digitalWrite(MOTOR_B_IN_2_PIN, HIGH);
  analogWrite(MOTOR_B_EN_PIN, speed + MOTOR_B_OFFSET);
void setSpeed(int speed)
  // this function will run the motors in both directions at a fixed speed
  // turn on motor A
  setSpeedMotorA(speed);
  // turn on motor B
  setSpeedMotorB(speed);
void stop() {
  // now turn off motors
  digitalWrite(MOTOR_A_IN_2_PIN, LOW);
  digitalWrite(MOTOR_B_IN_2_PIN, LOW);
void drive(int distance, float turn) {
  int fullSpeed = 230;
  int stopSpeed = 0;
  // drive to location
  int s = fullSpeed;
  if ( distance < 8 ) {
    int wouldBeSpeed = s - stopSpeed;
    wouldBeSpeed *= distance / 8.0f;
    s = stopSpeed + wouldBeSpeed;
  int autoThrottle = constrain(s, stopSpeed, fullSpeed);
  autoThrottle = 230;
  float t = turn;
  while (t < -180) t += 360;
  while (t >  180) t -= 360;
  Serial.print("turn: ");
  Serial.println(t);
  Serial.print("original: ");
  Serial.println(turn);
  float t_modifier = (180.0 - abs(t)) / 180.0;
  float autoSteerA = 1;
  float autoSteerB = 1;
  if (t < 0) {
    autoSteerB = t_modifier;
  } else if (t > 0){
    autoSteerA = t_modifier;
  Serial.print("steerA: "); Serial.println(autoSteerA);
  Serial.print("steerB: "); Serial.println(autoSteerB);
  int speedA = (int) (((float) autoThrottle) * autoSteerA);
  int speedB = (int) (((float) autoThrottle) * autoSteerB);
  setSpeedMotorA(speedA);
  setSpeedMotorB(speedB);
void driveTo(struct GeoLoc &loc, int timeout) {
  nss.listen();
  GeoLoc coolerLoc = checkGPS();
  bluetoothSerial.listen();
  if (coolerLoc.lat != 0 && coolerLoc.lon != 0 && enabled) {
    float d = 0;
    //Start move loop here
    do {
      nss.listen();
      d = geoDistance(coolerLoc, loc);
      float t = geoBearing(coolerLoc, loc) - geoHeading();
      Serial.print("Distance: ");
      Serial.println(geoDistance(coolerLoc, loc));
      Serial.print("Bearing: ");
      Serial.println(geoBearing(coolerLoc, loc));
      Serial.print("heading: ");
      Serial.println(geoHeading());
      drive(d, t);
      timeout -= 1;
    } while (d > 3.0 && enabled && timeout>0);
    stop();
void setupCompass() {
   /* Initialise the compass */
  if(!mag.begin())
    /* There was a problem detecting the HMC5883 ... check your connections */
    Serial.println("Ooops, no HMC5883 detected ... Check your wiring!");
    while(1);
  /* Display some basic information on this sensor */
  displayCompassDetails();
  // We start by connecting to a WiFi network
  /* Explicitly set the ESP8266 to be a WiFi-client, otherwise, it by default,
     would try to act as both a client and an access-point and could cause
     network-issues with your other WiFi-devices on your WiFi-network. */
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
//  while (WiFi.status() != WL_CONNECTED) {
//    delay(500);
//    Serial.print(".");
//    Serial.println("");
//    Serial.println("WiFi connected");
//    Serial.println("IP address: ");
//    Serial.println(WiFi.localIP());
  // Compass
  setupCompass();
  // Motor pins
  pinMode(MOTOR_A_EN_PIN, OUTPUT);
  pinMode(MOTOR_B_EN_PIN, OUTPUT);
  pinMode(MOTOR_A_IN_1_PIN, OUTPUT);
  pinMode(MOTOR_A_IN_2_PIN, OUTPUT);
  pinMode(MOTOR_B_IN_1_PIN, OUTPUT);
  pinMode(MOTOR_B_IN_2_PIN, OUTPUT);
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, HIGH);
  //Debugging via serial
  Serial.begin(4800);
  //GPS
  nss.begin(9600);
  //Bluetooth
  bluetoothSerial.begin(9600);
  Blynk.begin(bluetoothSerial, auth);
// Testing
void testDriveNorth() {
  float heading = geoHeading();
  int testDist = 10;
  Serial.println(heading);
  while(!(heading < 5 && heading > -5)) {
    drive(testDist, heading);
    delay(500);
  stop();
void loop(){
//  Serial_Printing();
//  Serial.print("Waypoint found: ");
For additional info, the code references a CoolerDefinitions.h file. That code is shown below:
// Blynk Auth
char auth[] = "BLYNK_AUTH_TOKEN";
// Pin variables
#define SERVO_PIN 4
#define GPS_TX_PIN 6
#define BLUETOOTH_TX_PIN 10
#define BLUETOOTH_RX_PIN 11
#define MOTOR_A_EN_PIN 5
#define MOTOR_B_EN_PIN 9
#define MOTOR_A_IN_1_PIN 4
#define MOTOR_A_IN_2_PIN 3
#define MOTOR_B_IN_1_PIN 1
#define MOTOR_B_IN_2_PIN 0
// If one motor tends to spin faster than the other, add offset
#define MOTOR_A_OFFSET 20
#define MOTOR_B_OFFSET 0
// You must then add your 'Declination Angle' to the compass, which is the 'Error' of the magnetic field in your location.
// Find yours here: http://www.magnetic-declination.com/
// Mine is: 13° 24' E (Positive), which is ~13 Degrees, or (which we need) 0.23 radians
#define DECLINATION_ANGLE 0.23f
// The offset of the mounting position to true north
// It would be best to run the /examples/magsensor sketch and compare to the compass on your smartphone
#define COMPASS_OFFSET 0.0f
// How often the GPS should update in MS
// Keep this above 1000
#define GPS_UPDATE_INTERVAL 1000
// Number of changes in movement to timeout for GPS streaming
// Keeps the cooler from driving away if there is a problem
#define GPS_STREAM_TIMEOUT 18
// Number of changes in movement to timeout for GPS waypoints
#define GPS_WAYPOINT_TIMEOUT 45
// PWM write for servo locations
// #define SERVO_LID_OPEN 20
// #define SERVO_LID_CLOSE 165
// Definitions (don't edit these)
struct GeoLoc {
  float lat;
  float lon;
//enum CoolerLid {
//  OPENED,
//  CLOSED
@aapina please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
It’s also good practice to use triple backticks around your serial monitor output - it makes it much easier to read.
Will do. Thank you.
Well, you’re still using the BT libraries, and don’t have a Blynk ESP8288 library included…
And if you’re going to use Blynk.begin to initialise your WiFi and Blynk connection then you don’t need this:
I’d suggest that you familiarise yourself with the structure of a typical ESP8266 Blynk sketch via the Sketch Builder, and compare it to the same sketch for a BT connection type…
Thank you for the fast reply. I’ll check the examples and see what I can cobble together.
please share code to me if you figure it out… i need to my project please help
