Unresolvable error
This is the ERROR:
In file included from c:\Users\LMarcelinoM\Documents\Arduino\libraries\Blynk\src/BlynkApiArduino.h:14,
                 from c:\Users\LMarcelinoM\Documents\Arduino\libraries\Blynk\src/BlynkSimpleEsp32.h:20,
                 from C:\Users\LMarcelinoM\Documents\Arduino\temperatura_blynk\temperatura_blynk.ino:3:
c:\Users\LMarcelinoM\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkApi.h:39:6: error: #error "Please specify your BLYNK_TEMPLATE_ID and BLYNK_TEMPLATE_NAME"
   39 |     #error "Please specify your BLYNK_TEMPLATE_ID and BLYNK_TEMPLATE_NAME"
exit status 1
Compilation error: exit status 1
And this my CODE:
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <Adafruit_MAX31865.h>
#define RREF 430.0
#define RNOMINAL 100.0
#define BLYNK_TEMPLATE_ID "TMPL2__PnmDb9"
#define BLYNK_TEMPLATE_NAME "rtd"
#define BLYNK_AUTH_TOKEN "xxxxxxxxx"
float temp;
char pass[x] = "xxxxxxxxxx";
char ssid[x] = "xxxxxxxxxx";
Adafruit_MAX31865 thermo = Adafruit_MAX31865(5, 23, 19, 18);
BLYNK_WRITE(V0){
temp = param.asFloat();
Blynk.virtualWrite(V1, temp);
void myTimerEvent(){
Blynk.virtualWrite(V2, millis() / 1000);
thermo.begin(MAX31865_4WIRE);
temp = (thermo.temperature(RNOMINAL, RREF));
temp = (temp - 1.52);
I couldn’t find the solution
@Peco Please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code and your compiler error message so that they display correctly.
ready, I already corrected it
Read this link…
Which library version are you using?
