Hi all, and thank you for your time.
I have been having trouble getting my code to show the current time in the serial monitor and it is holding me up from completing my project. I have rebuilt this from the ground up, but still face the same issue.
this is the output to the serial monitor:
ets Jan 8 2013,rst cause:2, boot mode:(3,7)
load 0x4010f000, len 1384, room 16
tail 8
chksum 0x2d
csum 0x2d
v3de0c112
~ld
ü.........
WiFi connected
IP address:
192.168.0.13
[4823]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.4.3 on Arduino
[5001] Connecting to blynk-cloud.com:8442
[5241] Ready (ping: 0ms).
[10242] Connecting to blynk-cloud.com:8442
[21284] Connecting to blynk-cloud.com:8442
[21392] Ready (ping: 0ms).
Connected to Blynk server
Current time: 0:0:31 1 1 1970
Current time: 0:0:41 1 1 1970
My code:
#include "Blynk.h"
#include "rtc.h"
wifiServerConnect();
rtc.begin();
timer.setInterval(10000L, clockDisplay);
rtc.h:
#include <TimeLib.h>
#include <WidgetRTC.h>
WidgetRTC rtc;
void clockDisplay()
// You can call hour(), minute(), ... at any time
// Please see Time library examples for details
Serial.print(currentTime);
Serial.print(" ");
Serial.print(currentDate);
Serial.println();
// Send time to the App
Blynk.virtualWrite(V1, currentTime);
// Send date to the App
Blynk.virtualWrite(V2, currentDate);
and in case it is relevant, Blynk.h:
char auth[] = "6f5664c6d70f499e9d6f87e63f669bac";
char ssid[] = "virginmedia6125068";
char pass[] = "jnaascuw";
bool Connected = false;
void CheckConnection(){
Connected = Blynk.connected();
if(!Connected){
Serial.println("Not connected to Blynk server");
Blynk.connect(3333); // timeout set to 10 seconds and then continue without Blynk
else{
Serial.println("Connected to Blynk server");
void wifiServerConnect (){
Serial.begin(74880);
WiFi.begin(ssid, pass);
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("IP address: ");
Blynk.config(auth); // in place of Blynk.begin(auth, ssid, pass);
// Wait until connected
timer.setInterval(11000L, CheckConnection); // check if still connected every 11 seconds
Any help would be really valued! I’ve been fussing about trying to fix this for long enough that the animal who will be the beneficiary of this environmental control system is becoming uncomfortably cramped in his/her current quarters waiting for me to finish!
hardware is Wemos D1 Mini Pro (ESP8266).
