I would like to use some units with datastreams that cannot be selected in the table, like kg/m3, kg/l, per minute and per second. Is it possible to add those units by myself?
Thank you, Carl.
Thank you, Carl.
No, datastream units have to be added by Blynk.
For some widgets, such as Labelled Value, you can specify your own suffix…
I use version 3.5.4 on IOS.
Looks like you use manually entered value kg/m3 to label field in widget settings.
We have support only for kg/m2 units option yet. (this option you can set in web console in datastream settings)
Regarding the text size. I will pass the information to the developer
