I’m helping a friend to get going on his first project but we got stuck on step 1
The, out of the box, Edgent code is uploaded with no problems but the web config page doesn’t come up, in stead, the msg Not found: / is shown.
Ping to 192.168.4.1 works
192.168.4.1/config responds
192.168.4.1/reset responds
192.168.4.1/update responds
192.168.4.1/board_info.json responds
however,
192.168.4.1 doesn’t respond nor does blynk.setup.
What am I missing?
board used: different types of WROOM ESP32 DEV.
The basic blink and wifi connection sketches, work.
Hey Peter,
No board type has been un-commented as I’m using the “custom” one. The pins are not in use, I’m trying to get to the AP web server.
Yes, configuring it via IP once generated the firmware tokens via dashboard.
and below, the serial monitor shows what it’s expected to see.
That’s not really how the provisioning process is meant to be used, and the web portal functionality appears to be disabled by default and enabling it causes an error.
Why aren’t you doing the provisioning via the app, using the “+ Add New Device” option?
By app you mean Smartphone’s app? If so, my initial intentions were to demostrate a way to get up and running a device using only a web browser without the need of using a Smartphone. Perhaps, it cannot be done with Edgent.
