I have one my friend in Italy, and he has setup a Blynk local server(with public ip).
So i was eager to see if i can connect to his server from India.
So I logged in using the public ip he gave me. It worked.
Now when i create a new project i am not receiving the auth token via email. It says server busy try again later[something like this i don’t remember the exact error message].
But i have less secured app turned ON in my google account settings. I also receive a mail saying there has been an unkown device trying to access from xxx.xxx.x.x ip…Check activity.
and the ip address is same as ip i entered during login.
Is this anything to do with the server side or google settings ?
Actually i don’t need the email at all. As i will be copying the auth token directly from the app and pasting it into the config portal. So its not necessary at all.
But i wanted to know if we have missed anything during the setup process of the server.
Or google is blocking the ip just because it is from Italy and i stay in India ?
All the settings were set properly, i even crossed checked if the less secured apps(setting) was turned ON, it was ON.
But the catch was
As soon as i generated a app password and used the same in the mail.properties VOILA
its done. Now i am receiving the email…
We can copy the auth token right from the Blynk app, but i wanted to know what was going wrong, now i learnt something new. Thank you so much for solution…
