Hi everyone, I have set up my ESP8266 esp01, can see it on my network and pings fine. I have loaded the program onto my Arduino mega and was unable to get it to link, I added in an L.E.D to flash every time the program cycles but have found that it flashes 4 times within the expected delay then once every 20 seconds. . I’ve placed the code below so if you have any suggestions I would greatly appreciate it.
*( I originally posted a program that was not what I had loaded)
*//#define BLYNK_PRINT Serial // Comment this out to disable prints and save space #include <ESP8266_Lib.h> #include <BlynkSimpleShieldEsp8266.h>
char auth[] = “6c8a1c0db8404b54xxxxxxxxxxxxxxx”;
// Set password to “” for open networks.
char ssid[] = “BigPxxxxxxxxx”;
char pass[] = “B9xxxxxxxx”;
// Hardware Serial on Mega, Leonardo, Micro… #define EspSerial Serial1
// or Software Serial on Uno, Nano…
//#include <SoftwareSerial.h>
// Your ESP8266 baud rate: #define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
pinMode(9, OUTPUT);
// Set console baud rate
// Set ESP8266 baud rate
digitalWrite(9, HIGH); // turn the LED on (HIGH is the voltage level)
delay(500); // wait for a second
digitalWrite(9, LOW); // turn the LED off by making the voltage LOW
A search of the this site for “failed to disable echo” will bring up lots of posts.
Easiest fix is to switch to a WeMos or similar ESP that has a built in USB port, loads of memory and costs next to nothing. If you really need all the Mega pins you can reverse the system and have “WeMos with Mega shield” rather than “Mega with ESP shield”.
After searching for this I see what you mean, I have 2 Nodemcu’s on order but was trying to use what I had to make a start. Thanks again for your help. really appreciated.
Some people don’t realise their Uno and Nano only has one Serial port and that really they need a USB 2 TTL adaptor but at least you hae the required Serial ports on the Mega. Some get confused with rx and tx.
ESP’s come with a fixed baud rate, some are ok at 9600, some have 115200 and some 74400 which need changing with the required AT command.
