Before creating the topic
- Search forum for similar topics
- Check http://docs.blynk.cc and http://help.blynk.cc/
- Add details :
• Blynk Library version
• Add your sketch code.
Code should be formatted as example below.
// Room Automation with mmWave sensor and Blynk IOT
/* Fill-in your Template ID (only if using Blynk.Cloud) */
#define BLYNK_TEMPLATE_ID "TMPL8tKheL_c"
#define pir 23 // Pin connected to the mmWave sensor
#define relay 15 // Pin connected to the relay module
// Inclded Library Files
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <DFRobot_mmWave_Radar.h>
HardwareSerial mySerial(1);
DFRobot_mmWave_Radar sensor(&mySerial);
char auth[] = "ypmE9jwcI7Vt1dxfzDWbZ0hysl-SsbQy";
char ssid[] = "home-ch";
char pass[] = "xxx";
