Hi, I’m working in my project that it’s giving a big headache because for a time i had success to connect my board to hotspot and i was testing the DHT11 sensor, but for a moment the board didn’t connect anymore. When I connect it via my phone’s Hotspot, Blynk shows that it is offline and will not connect and sometimes shoes that is connected and the board is resetting immediately. What is causing this?
#define BLYNK_TEMPLATE_ID "TM********i"
#define BLYNK_TEMPLATE_NAME "Avicultor2023"
#define BLYNK_AUTH_TOKEN "Blk******************"
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include "DHT.h"
LiquidCrystal_I2C lcd(0x27,16,4);
bool fetch_blynk_state = true; //true or false
char auth[] = BLYNK_AUTH_TOKEN;//Paste auth token you copied
char ssid[] = "The ***";
char pass[] = "nana**************";
#define DHTPIN 32
#define wifiLed 2
#define VPIN_t V0
#define VPIN_h V1
int wifiFlag = 0;
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V1, h); // select your virtual pins accordingly
Blynk.virtualWrite(V0, t); // select your virtual pins accordingly
void checkBlynkStatus() { // called every 2 seconds by SimpleTimer
bool isconnected = Blynk.connected();
if (isconnected == false) {
wifiFlag = 1;
Serial.println("Blynk Not Connected");
lcd.setCursor(0,0);
lcd.print("Ilumin:");
lcd.setCursor(0,1);
lcd.print("Comprt:");
lcd.setCursor(0,2);
lcd.print("Sens:");
lcd.setCursor(5,3);
lcd.print("Mod Manual");
digitalWrite(wifiLed, LOW);
delay(800);
digitalWrite(wifiLed, HIGH);
if (isconnected == true) {
wifiFlag = 0;
if (!fetch_blynk_state){
Blynk.virtualWrite(VPIN_BUTTON_1, toggleState_1);
Blynk.virtualWrite(VPIN_BUTTON_2, toggleState_2);
Blynk.virtualWrite(VPIN_BUTTON_3, toggleState_3);
Blynk.virtualWrite(VPIN_BUTTON_4, toggleState_4);
Blynk.virtualWrite(VPIN_Wsensor_1, toggleStW1_1);
Blynk.virtualWrite(VPIN_Wsensor_2, toggleStW1_2);
Blynk.virtualWrite(VPIN_Wsensor_3, toggleStW1_3);
Serial.println("Blynk Connected");
// sendData();
// lcd.clear();
lcd.setCursor(5,3);
lcd.print("Mod Web On");
BLYNK_CONNECTED() {
if (fetch_blynk_state){
// Blynk.syncVirtual(VPIN_BUTTON_0);
// Blynk.syncVirtual(VPIN_BUTTON_1);
//Blynk.syncVirtual(VPIN_BUTTON_2);
//Blynk.syncVirtual(VPIN_BUTTON_3);
//Blynk.syncVirtual(VPIN_IRSENSOR,irVal);
//Blynk.syncVirtual(VPIN_MQ2, mq2Val );
// Blynk.syncVirtual(VPIN_LDR, ldrVal);
// lcd.begin();
//lcd.backlight();
pinMode(wifiLed, OUTPUT);
//Blynk.begin(auth , ssid, pass);
WiFi.begin( ssid, pass);
//Blynk.begin(auth, ssid, pass, IPAddress(192,168,43,21), 8080);
timer.setInterval(2000L, checkBlynkStatus); // check if Blynk server is connected every 2 seconds
Blynk.config(auth);
dht.begin();
// Blynk.virtualWrite(VPIN_BUTTON_1, toggleState_1);
// Blynk.virtualWrite(VPIN_BUTTON_2, toggleState_2);
//Blynk.virtualWrite(VPIN_BUTTON_3, toggleState_3);
//Blynk.virtualWrite(VPIN_BUTTON_4, toggleState_4);
lcd.setCursor(4, 0);
lcd.print("Aviario");
lcd.setCursor(1, 1);
lcd.print("Automatico ESP32");
delay(2000);
lcd.clear();
Like this Pete?
