I was in a weak area for cell coverage and had this box pop up. Once in good converage I have been unable to get this to clear even though I can see in the background the data updating on my devices. The cell phone is Samsung SM-911U using Android version 15. Blynk is version 1.25.0
Hello @jstobaugh. Thanks for report. Should be fixed in next app version. 1.26.1 version should be available during next several days. Please check app updates.
Thanks.
Problem still persists with 1.26.1.
I clicked the connect button. I don’t have wifi enabled but I have clicked to enable it and connect to the network. Also I was expecting when it is communicating which I can see by the data changing on the screen for the device that the box would automatically go away.
@jstobaugh Popup should go away after connection to network (wifi or mobile internet)
This is the specificity of the implementation. It will not disappear by itself. You need to select a connection
Tested just now and it did clear on it’s own. I don’t know why it didn’t yesterday but if it happens again I will let you know.
Ok so I am still having the problem. I enabled wifi and it is connected to the internet but i can’t get the box to clear. Swipping left or right doesn’t work. I am showing 4G but weak which is normal where I live. The only way to clear it is to force stop Blynk.
@jstobaugh Maybe this is some specificity of your phone model. What is your exact phone model and android version?
Ideally, if you could record a video of the behavior of this pop-up and at what stages it does not disappear.
Model and version are in first post. There is nothing to record. As soon as I open Blynk it shows the box. Usually after sitting overnight. I believe I have left it open in the background and not closed it the day before. I am at the fringe of coverage so my phone will routinely go in and out of service depending on where I am in my house.
This problem is getting worse for me. When I get the box to show up I force close the app and restart it. I then get the hourglass and it never clears until I connect my phone to wifi. It then clears and I can then unclick wifi and it transfers to Cell and works. All these problems showed up only a few weeks ago and I use Blynk daily so I would notice a problem fairly soon.
This box auto-hides when Internet connection is restored. That’s why, when you foreclose the app and restart, it shows you the progress of establishing a connection - it means you have been disconnected from Internet (no wifi and no cell).
You box isn’t auto hiding. I have learned to ignore the box as my data is being received even though the box says no internet. I can change settings on my devices and see the settings are taking place.
Got it - I will try to reproduce it. Do you close/hide the app in between the pop-up has been shown?
In the next build, it will be hidden by a delay, and later we may introduce a different UI for the no internet case.
I just hide the app.
