Hi friends. I have a problem with my sketch. the nodemcu connection is not stable disconnect and reconnecting by itself. where is the problem
#define TRIGGER 4
#define ECHO 5
// NodeMCU Pin D2 > TRIGGER | Pin D1 > ECHO
char auth[] = "79444998d67046ab93641e0a89c9fd67";
char ssid[] = "MikroTik Home";
char pass[] = "mywifipass";
char server[] = "192.168.1.104";
Serial.begin (9600);
Blynk.begin(auth, ssid, pass, server);
pinMode(TRIGGER, OUTPUT);
pinMode(ECHO, INPUT);
pinMode(BUILTIN_LED, OUTPUT);
long duration, distance;
digitalWrite(TRIGGER, LOW);
delayMicroseconds(2);
digitalWrite(TRIGGER, HIGH);
delayMicroseconds(10);
duration = pulseIn(ECHO, HIGH);
distance = (duration/2) / 29.1;
if (distance <= 150) {
Blynk.virtualWrite(V0, 255);
else {
Blynk.virtualWrite(V0, 0);
if (distance <= 100) {
Blynk.virtualWrite(V1, 255);
else {
Blynk.virtualWrite(V1, 0);
if (distance <= 80) {
Blynk.virtualWrite(V2, 255);
else {
Blynk.virtualWrite(V2, 0);
if (distance <= 40) {
Blynk.virtualWrite(V3, 255);
else {
Blynk.virtualWrite(V3, 0);
if (distance <= 20) {
Blynk.virtualWrite(V4, 255);
else {
Blynk.virtualWrite(V4, 0);
Serial.print(distance);
Serial.println("Centimeter:");
Blynk.virtualWrite(V5, distance);
delay(200);
